Old 01-27-2020, 04:20 PM
BOB VIDAN BOB VIDAN is offline
Default Seat Belt Retractor QUestions
I always thought and was maybe told the tag on seat belt with retractors went face down, like on your lap. Also the slot in the housing was closer to the seat than the door panel. Are both of these right or? Same on all years? Reason I ask is because I have original, unmolested retractors that have the slot in the housings on both the inside and outside with the tag down and vicea versa. Answers.
Practicing social distancing for 65+ years
Old 01-27-2020, 06:52 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Dr. Mr. Zboo,
1966 Fremont built.
1) LH retracted. Two slots, one on outside, one on inside. Squeeze to remove cover.
2) RH pulled out. Tag face down, facing lap.
Hope this helped.
Chris.
ID:	530196   Click image for larger version
Old 01-28-2020, 12:42 AM
60sstuff's Avatar
Revision.
About that “slot”.
Bob,
Assuming the slot question pertains to where the belt comes out.
Both sides have the slot towards the seat as seen above.
