Old 02-04-2020, 01:54 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by catalina_dream View Post
Shawn Dixon had the Tempest Paul was referring to.
That was a cool car!
Go fast, see Elvis!
Old 02-04-2020, 02:21 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Originally Posted by Stan Weiss View Post
OK found 2 more dyno sheets for 1000+ HP. What heads do they run.
Dave Polichena
John Krull
Stan
I'm currently running Hi Ports Stan.
Dave Polichena
Old 02-04-2020, 03:16 PM
GTOGEORGE's Avatar
Warp heads......? Probably 4 NA.
GTO George
Old 02-04-2020, 03:36 PM
Stan Weiss's Avatar
GTO George
Picketts @ 428 ci
Stan
Pontiac Pump Gas List
Old 02-04-2020, 03:40 PM
GTOGEORGE's Avatar
Picketts @ 428 ci
Stan
Yep that was one of the four.
GTO George
Old 02-04-2020, 04:45 PM
mysticmissle's Avatar
the 428 made over 1000 hp? i dont think so
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 02-04-2020, 04:52 PM
Stan Weiss's Avatar
Based on information I got a number of years ago from Tom S it made a little over 1000 HP @ 9500 RPM.
Stan
Old 02-04-2020, 05:41 PM
Dragncar Dragncar is offline
Dave Polichena
John Krull
Stan
Didn't Krull make 914 with E heads on pump gas ? Did he bump up the CR later ?
The 3 Gabby E heads. We know KK made it. Jack almost made it with N2O and 13.5-1. No reason to think he would have not gotten it NA with cam and CR. What was Siks doing with his (leaky) set ? NA ? How much HP ?
What about Bailey/ GTO Kid. He made big power right with E heads. Brandywine or Slowclaw ? (not sure about the spelling)
Seems to me there are more 1000HP E heads than HPs.
Old 02-04-2020, 06:04 PM
GTOGEORGE's Avatar
What about.........what about, sounds like a lot of guessing I can name 4 Warp cars and ET’s and they come to norwalk.
GTO George
Old 02-04-2020, 06:42 PM
AIR RAM AIR RAM is offline
Originally Posted by mysticmissle View Post
how many 1 k eheads are you aware of? tigers, hiports and warp 6s jury is out on any set of 5 style head, CVs and Super wedges, being ''easier to make 1 k'' in my opinion. RPM should also factor into this, but
I am no expert, I'm a just a lowly knuckledraggin, bracket racing, ehead owner struggling to make 850 hp reliably. If i was trying to make 1K i think would be buying a different set of heads. A build similar to Tom Kilroy's would be an excellent starting point for a 1 k hp Pontiac powered bracket car
What cc are your eheads and what do they flow? How much lift are you running? What RPM range are you making your 850hp at? I have always liked your set up... 850NA is no small feat!
The key words that you mentioned is "850HP RELIABLY"... That's a tough requirement to achieve the higher up in HP you rise. However, (off topic) 5lbs of boost should get you there... LOL
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
The Following User Says Thank You to AIR RAM For This Useful Post:
Old 02-04-2020, 07:32 PM
Bailey I believe is in the mix. That makes 5.
Krull is Not close Enough to consider especially after putting it In Calvin’s car, In my opinion
To be clear we are only asking about eheads. Visner Na cygan must be in the 1 k
Also I concede not everyone comes to py and brags there combo up. I’d like to
Hope there are more than appearing this list for every manufacturers head
1964 540 gto
Old 02-04-2020, 07:34 PM
hp 400 dave's Avatar
hp 400 dave hp 400 dave is offline
Someone has made over 1000hp na with e heads, both rpm and pp, cv-1 s, Lynn's ra5, wenzler 2 and sc, hps, tiger 1 and 2, warp 6, and I'm not sure about dci ra5. Seems like any head available other than factory iron can make 1000na. It's more about how far past 1000 you want to go.
The Following 2 Users Say Thank You to hp 400 dave For This Useful Post:
Old 02-04-2020, 07:46 PM
pastry_chef's Avatar
Originally Posted by hp 400 dave View Post
Lynn's ra5.
With the push-rod pulled from the port, is it really a RA5 still?
Old 02-04-2020, 07:53 PM
Doesn't matter about the pushrod, just naming the casting as people know it.
Old 02-04-2020, 08:43 PM
Krull did not put motor in Calvin’s car. My memory was insufficient
1964 540 gto
Old 02-04-2020, 08:51 PM
Gary H's Avatar
Gary H Gary H is offline
My combo made 1039 horsepower. Edelbrock wide ports by Marcella, Gustram intake
The Following User Says Thank You to Gary H For This Useful Post:
Old 02-04-2020, 08:53 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Talking
If the pushrods are moved over in eheads are they really a ehead still?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #38
Old 02-04-2020, 08:59 PM
GTOGEORGE's Avatar
If you change the hemi combustion chamber from a hemi to a wedge chamber is it still a hemi.....probably not!
GTO George
  #39
Old 02-04-2020, 09:02 PM
Pushrod in the port center is the very signature of RA5.
There is minor shifting and major shifting. I'm waiting for a NA RA5 to hit 2.7 HP/cube as the clown assured they could. LMAO.
  #40
Old 02-04-2020, 09:15 PM
Scott Roberts Scott Roberts is offline
If a frog ate mud and had a square asshole, would he **** bricks??
