Old 02-04-2020, 10:07 PM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by Scott Roberts View Post
If a frog ate mud and had a square asshole, would he **** bricks??
Yes, i've seen it
  #42
Old 02-04-2020, 10:14 PM
J.C.you's Avatar
J.C.you J.C.you is offline
[QUOTE=pastry_chef;6107286]Pushrod in the port center is the very signature of RA5.
There is minor shifting and major shifting.
.700-.800 offset moved is minor? .....ok
We all need to check in with pastry to see what his max accepted signature pushrod movement is for proper head names...
Seriously, brings up a sorta thread related question.
Has there been a na 1000 Hp ehead with standard pushrod location?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #43
Old 02-04-2020, 10:33 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
EHTTFMF
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #44
Old 02-04-2020, 10:36 PM
Scott Roberts Scott Roberts is offline
Originally Posted by Jeff Kinsler View Post
EHTTFMF
True story^^^^
You're gonna be slower this year.... now that you went to the dark side.
  #45
Old 02-04-2020, 10:39 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Since you guys brought it up, Krull's 541 made 1022 with Perf RPM e head many years ago. Also we were involved with a Warp 6 headed combo that made over 1150hp n/a and a DCI RAV headed combo that also recently made over 1100hp. Know for certain there are some low key guys out there dedicating lots of resources to make power with traditional Pontiac architecture.
Carry on...
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
The Following 5 Users Say Thank You to Jim Robertson For This Useful Post:
  #46
Old 02-04-2020, 10:50 PM
Carry on...
I have a lot of respect for you Jim ... were the warp 6 engines not max effort to only make 1150? Seems like they should crack 1300 as the tiger is close to that....
  #47
Old 02-05-2020, 12:40 AM
Stan Weiss's Avatar
Carry on...
Jim,
Thanks. The dyno sheet I have is from May 2010. 1021.8 HP @ 6700 RPM
Stan
Pontiac Pump Gas List
  #48
Old 02-05-2020, 12:42 AM
Stan Weiss's Avatar
Scott,
Who is making close to 1300 HP N/A with a Pontiac?
Stan
  #49
Old 02-05-2020, 02:30 AM
Originally Posted by Stan Weiss View Post
Scott,
Stan
Close is a relative term I suppose... I believe Langer, snyder and Dwight are "well" ( also relative) over 1200.
The Following User Says Thank You to Scott Roberts For This Useful Post:
  #50
Old 02-05-2020, 03:00 AM
Dragncar Dragncar is offline
[QUOTE=J.C.you;6107308]
Pretty sure Baily's Brandywine/Sloclaw E head engine was std port, no offset. It was discussed around 07-08 maybe ? Heads were for sale here awhile back. 2.25 Ti valves I think.
There you have the real "BADDEST STANDARD PORT E HEADS ON THE PLANET!!
I think its amazing really. Slowclaw must know his stuff.
  #51
Old 02-05-2020, 03:42 AM
John Langer's Avatar
John Langer John Langer is offline
Slawco
The Following User Says Thank You to John Langer For This Useful Post:
  #52
Old 02-05-2020, 04:57 AM
Originally Posted by John Langer View Post
Slawco
Lol.. I like slowclaw... it sounds menacing...
  #53
Old 02-05-2020, 07:01 AM
mysticmissle's Avatar
[QUOTE=Dragncar;6107354]
No pretty sure wide port bailey had wide port your memory is worse than mine.
Was krull motor on the track? Jim Your numbers are accurate no doubt. That makes 6
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #54
Old 02-05-2020, 09:20 AM
its like white claw light
1964 540 gto
  #55
Old 02-05-2020, 09:24 AM
[QUOTE=mysticmissle;6107368]
http://forums.maxperformanceinc.com/...9&d=1469111511
them are wide ports and 2x4s
1964 540 gto
  #56
Old 02-05-2020, 11:15 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Popcorn where is the popcorn?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
  #57
Old 02-05-2020, 03:21 PM
Scott,
Stan
I was actually on the pump yesterday. Didn't make any significant changes to my combo and still made 1290. Now, if I wanted to just brag and puff my chest out I could have iced my intake and fuel, used "hot" fuel, added 1" of plenum to my intake, ran a thinner oil and pulled at 300rpm/sec and would be rewarded with a dyno sheet that shows 1315-1320hp but I don't race my engine like that so there is no point. I could say it was also raining real hard yesterday and that had to hurt me for 15hp but again, I wasn't after a number. If you look at my dyno sheet it shows that I am pulling fuel of a motor that makes 1350hp but the hp number on the sheet doesn't show that. Ultimately all that matters is the number on the big board at the end of the 1320...
The Following 5 Users Say Thank You to John Langer For This Useful Post:
  #58
Old 02-05-2020, 03:33 PM
Stan Weiss's Avatar
John,
Since you didn't post a dyno sheet. What are you see for BSFC?
Stan
  #59
Old 02-05-2020, 03:52 PM
John,
Stan
I run q. It will get around .43-.46 but it does pull over 550 pounds of fuel/hr
  #60
Old 02-05-2020, 04:11 PM
Scott yes the Warp 6 headed combo i was referring to was for a bracket racer. Congrats to all that have eclipsed the 1000hp milestone...especially with the perf RPM e head.
Jim
www.raceV8s.com
The Following 2 Users Say Thank You to Jim Robertson For This Useful Post:
