Mini Starter
I've been out of the loop for several years in regards to what some of the latest and greatest "bread and butter" parts are that are out there.
Looking to replace the original starter in my Can Am with an aftermarket mini. Tired of the slow crank after hot soaks on this 67K mile original low-compression W72 400. Who makes the best one out there for our Pontiacs?
RobbMc, MSD
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
Powermaster has worked very well for me
Great customer service
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
I've got a RobbMC on mine that works just fine But I also have a Summit Powermaster Mini on Carole's car that originally was on mine and is probably 15+yrs old and still works flawlessly. It's had a ton of usage and hot starts.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! Last edited by Rob B; 02-10-2020 at 11:41 AM. |
http://www.hitorque.com/Gear_Reducti..._p/imi-108.htm
Been using this for 23 years now. No issues and excellent customer service.
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well. >>My 73 Build thread |
About 16 years on my IMI hitorque as well.
'65 Tempest 467 3650# 11.30@120.31 |
IMI
GTO George |
RobbMc ! Awesome customer service should you need it.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
McLeod in the 78 TA for years, had to manually drill and tap to reclock, had to replace soleniod once in 20 years.
IA Camaro RobbMc the dropped pan rail on the IA hit the motor on the McLeod, RobbMc fits great and easy to reclock anywhere you want it.
Mongo will like Power Master great service after sale..
I believe RobbMC's is the only mini that uses planetary gearing, so the drive gear remains concentric with the motor shaft (just like any non-geared starter). Correct me if I'm remembering wrong?
