1016 dia
The opening is not exactly round. Is there a "in the middle" number used when figuring it out for compression ratio calculators ? What is crushed thickness ?
Also, how much needs milled off a set of 80cc High Ports to get 5cc removed ? Thanks for any help. |
1016 compressed thickness .039 and measures 9.4 cc.
I use the 1016's with my 80cc High Ports. Jeff Kauffman told me to get to 74cc I would have to mill .030 from the surface.
I need a gasket dia for the Wallace site. 4.155, 4.25, .039, and 4.188 for gasket dia gets me 10.90 CR. But the gasket dia is just a guess. Anyone have a better number ?
Stan
Why do you need a "better number " if the 1016 spec's clearly state 9.4 CCs at the crush height number?
If I am not mistaken that gasket at its widest point is 4.230", I can check for you later when I get home if no one chimes in first. If the info in post 3 is correct then each .005" milled off will knock 1 CC off the chamber volume, which sounds right from what I recall without having my note's at hand.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 02-11-2020 at 07:36 AM. |
The Following User Says Thank You to steve25 For This Useful Post: | ||
Gasket volume formula is (bore ÷ 2)2 x 3.1416 x gasket thickness x 16.387
https://www.jepistons.com/blog/how-t...d-displacement .
GT. |
Wallace gets me 10.85 CR with that number.
You need deck height and valve relief cc also, i like the classical pontiac calculator personally
Illinois Outlaw Gassers 6.27@107 9.97@131 |
How To Calculate Engine Compression Ratio And Displacement
The Wallace site formula as many others do assumes a round Bore head gasket, and both the 1016 and the 8518 are not, which makes there CC volume bigger.
Both of these gaskets have two scallops in each Bore for use with the pre mid 1967 valve inclination angle of the 326, 389 and 421 motors. I checked a used 8518 head gasket last night and it's 4.380" at its widest rounded points across its center' so my 4.230" number I posted yesterday seems to be wrong, atleast until I dig out my 1016 gasket to check later.
If dragncar was smart, he'd put zero in for head gasket thickness, then add 9.4cc to his chamber size.
I have my own calculator in excel if anyone wants it, PM your email.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Thanks for all the posts of folks just trying to help. If I really wanted to think about it I would have looked it up but I asked you fine folks.
When I try and play nice you knobs want to start something. You know, A wise man around here said "why would you take advice from someone who keeps blowing their $h!t up". I stopped taking your advice a long time ago. |
Closed Thread |
