Trusted Engine Builders In 2020
It's been a while since I've needed an engine in my GTO but since my guy is long gone and I'm going to start pushing it this Summer I'd like to have plan B ready so.....
Who's a trusted Pontiac builder these days? Who specializes in the aftermarket block builds? Anyone in the IL area? Thanks
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
I'm shipping an engine from SoCal to Paul Knippen in the Chicago area to get freshened up.
The Following User Says Thank You to Mean Green For This Useful Post: | ||
BES did mine.
"...Who specializes in the aftermarket block builds?..."
Can't answer that one. I assume that Paul K. or anybody that can build using a stock block, can also build, with an aftermarket block. BES don't show anything about Pontiac engines, on their site, that I saw. But, others have also said they did their Pontiac stuff. DCI does aftermarket block builds. They're in OH. https://www.dcimotorsports.com/ Then of course, KRE is also in OH. http://www.krepower.com/ Last edited by ponyakr; 02-13-2020 at 05:01 PM. |
He built mine in 2016. He is PAUL K here on PY.
74 Formula 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.075 @ 112.70 12.092 @ 112.43 12.128 @ 111.71 |
The Following User Says Thank You to form74 For This Useful Post: | ||
Rick Johnson in Crete Il
Spotts in NE-U.S.A.
I can tell you who NOT to have do it in northern IL........PM me if you want. |
The Following User Says Thank You to abefromen For This Useful Post: | ||
Paul K. Is in your backyard and very good at what he does... he has countless successful after market block builds under his belt..
Not only that but he also has some very serious blown alcohol combos he builds and works with... He is an engine guy... he does them all... Pontiac just happens to be his favorite.. |
The Following User Says Thank You to Scott Roberts For This Useful Post: | ||
If none of the guys mentioned tickle your fancy, there is a guy on here that goes by Dragoncar... he is the one all builders aspire to be...
He does all motors. He had an IA motor there when he did mine 601 ci and I think it dyno at 1206 hp I think it was. Mine was a MR-1 pump gas 571 ci dyno 724 hp 760 tq with e heads. He did a lot with McCarty on his RAV heads. So yeah he dose at lot you don't hear about. There are quite a few good builders out there that I would go to, I happened to live closer to BES and he had a good reputation and great to work with. |
I wouldnt take it to kre... if you have a problem, your screwed if they feel threatened by facts.. in fact, they may actually sue you and lose if they don't like what you say... imo...
DCI MOTORSPORTS!!! Don Johnston
Should that post be in sarcasm font? Asking for a friend. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
No.... hes the best, just ask him..
I've already had to close two threads today because of insults and arguing, please keep this one civil.
Who has made any insults? I haven't seen any...you told me as long as I didnt call names or make threats, I was good... has that changed?
^^^TRUTH^^^ |
Paul K is in your area
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
The Following User Says Thank You to Richie Hoffman For This Useful Post: | ||
Paul K
The Following User Says Thank You to slowbird For This Useful Post: | ||
