Old 02-13-2020, 06:15 PM
72projectbird's Avatar
Default What cam is this? Also, engine carnage
I pulled apart a 70 455 I have sitting around. The previous owner said it developed a lower end noise, so he pulled it. Turns out it inhaled some metal pieces (I have no idea what they are) and beat the hell out of two cylinders. They look like the surface of the moon.
One cylinder was spared destruction, as a similar metal piece got lodged between the valve and failed to drop into the cylinder. lol
Anyways, I decided to see what cam was in it. The markings are as follows:
Rear of cam: 2700202 MAP
In between lobes: 51 B3 25 4 D
Front of cam: 540 233
Mandatory pics of busted up engine pieces:
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-13-2020, 07:27 PM
tempest1964's Avatar
Sh!t!
Old 02-13-2020, 10:28 PM
Originally Posted by tempest1964 View Post
Sh!t!
Oh yeah, bigtime shat.
Each cylinder had almost identical pieces in them, along with that third cylinder that survived because the piece got caught in the valve.
It's .030 currently. Hopefully I can get away .040 after machining.
1987 Grand National
Old 02-13-2020, 10:43 PM
77 TRASHCAN's Avatar
Might be good to get cylinder wall thickness checked. I hope it will make .040.
I don’t know how common these problems are, surely the block is ok from whatever happened!!!
Hope the block is good!!!
Shut it off
Shut it off
Old 02-14-2020, 01:18 PM
Me too
I was planning on this being the next engine for my 71. I'm thinking about swapping over the drivetrain in the 71 into another car, so this will hopefully be going in.
If it checks out ok, I'm thinking about a healthy roller cam and some Edelbrock round ports.
1987 Grand National
Old 02-14-2020, 01:28 PM
steve25 steve25 is offline
Real hard to guess what it may have inhaled!
But in terms of normal engine parts and not sabotage that item of steel wedged under the valve looks diameter wise like it could be a secondary metering rod from a Qjet.
It looks like. Big valve low comp head, like a casting number 96 or 7K3 if it's not the original head from 1970.
Old 02-14-2020, 01:54 PM
They're the original 64 heads. Build date of October 1969, same as the block.
Whatever it inhaled, it's got some weight to it for being so small. I thought they were nut driver bits at first.
1987 Grand National
Old 02-15-2020, 07:53 AM
Ah, ok so like a 91 cc chamber.
Old 02-15-2020, 09:46 AM
shaker455's Avatar
shaker455 shaker455 is offline
Oh boy that's not good!
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 02-15-2020, 11:35 AM
87cc
Nope!
Not doing anything with it just yet. Was bored and decided to pull the heads. So much for a minor lower end noise.
1987 Grand National
Old 02-15-2020, 10:02 PM
scott70's Avatar
scott70 scott70 is offline
Most # 64's cc in the low 90's.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 02-16-2020, 12:52 AM
antique69lemans antique69lemans is offline
If that was commercially rebuilt it is likey those are steel tumbling media used to deburr castings. There was a thread on the buick forum where one of those fell out of main oil galley into bearing. It wasn't pretty. Those could have been lodged in intake runner forever.
Old 02-16-2020, 01:07 PM
Hmmm, that's interesting.
All three pieces I've found are all similar in size and shape. They're solid steel square tubes. Very odd.
I'll probably disassemble the lower end soon and see if there's more carnage.
1987 Grand National
