Old 02-14-2020, 12:27 PM
Gary H's Avatar
Gary H Gary H is offline
Default RA V Carb
There's a ad on Orlando Craigslist for a RA V Holley carb. Not mine just wondering if that's the right number and if it's real.
https://orlando.craigslist.org/pts/d...073530716.html
Old 02-14-2020, 12:49 PM
dataway's Avatar
dataway dataway is offline
Jeez, same one I saw come up on my recent CL search in NY ... was listed some state in new england .. forget which.
Old 02-14-2020, 01:12 PM
steve25 steve25 is offline
I have always wondered if the 303 motors got the same size 800 cfm Carb as the 400s?
Old 02-14-2020, 01:27 PM
Mike Davis's Avatar
These are the numbers I have for the Holley 800 that is for the Ram Air V
Pontiac 303-CID Man Trans 4150 #4546
Pontiac 400-CID Auto Trans 4150 #4486
Pontiac 400-CID Man Trans 4150 #4545
So yes that's a RAV carb,
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 02-14-2020, 01:32 PM
tom s tom s is offline
No contact info.As Mike posted it is a 400 auto carb.Tom
Old 02-14-2020, 01:38 PM
Something does not look quite right with the throttle arm.They are unique and has a bracket that bolts to it.Wish there was a better pic.Tom
Old 02-14-2020, 02:17 PM
Kenth's Avatar
Kenth Kenth is offline
Actually, Mike posted it as a 303 man carb.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-14-2020, 03:06 PM
Isn't that carb suppose to have down-leg boosters?
Clay
Old 02-14-2020, 04:30 PM
Your right,I will look at the boosters in mine,it’s on my V engine on the run stand right now.Going to fire it today.Tom
Old 02-14-2020, 04:36 PM
Gary H's Avatar
This carb may be owned by a gentleman I spoke to a while back that has some pretty rare Pontiac stuff. The ad for the carb shows phone number 989/244-6324 if anybody is interested.
Old 02-14-2020, 04:42 PM
Half-Inch Stud's Avatar
The 4546 is an 800 huh.
so im thinking the 4545 was 1050.
I gots the 4575 dated 1970 and quite pleased with it (being 1 digit off and all).
Old 02-14-2020, 05:07 PM
Tom Vaught's Avatar
Boost Engineer
#4545A is a 1970 400 cid pontiac carb for a M/T application. GTO and F-Bird.
#4546A is a 1970 303 cid pontiac carb for a M/T application. (Holley book says 302 engine) F-Bird.
Holley Book is 1 cubic inch off
#4486 is a 70 400 GTO and F-Bird with auto trans.
Tom V.
Old 02-14-2020, 10:47 PM
Formulajones's Avatar
Same CFM ratings yes. The different list numbers mainly designate a slightly different calibration.
Essentially they aren't really much different than the 780 4053 carbs on the little Chevrolet 302's, which are also often referred to as 800 cfm carbs. I'd bet same diameter throttle blades, bore and base plate.
Very surprised it doesn't have downleg boosters though. All the 4053 DZ carbs have downleg boosters.
Old 02-14-2020, 10:50 PM
the 400s do,maybe the 303 with the 320 CFM heads needed some help?The 400s were said to be 780s.Tom
Old 02-14-2020, 10:52 PM
Ah yep could be Tom, I forgot about the baseball sized ports. Different list number could account for the straight leg boosters.
Old 02-17-2020, 01:14 PM
Default Add Is Gone
Did you light it off and and a take a look at your carburetor?
Clay
Old 02-17-2020, 01:46 PM
Yep,the 400 has diff boosters.Tom
Old 02-17-2020, 10:11 PM
PontiacJim1959 PontiacJim1959 is offline
If this helps any. The article states, ".....is a new 800-CFM Holley which has the flow rating of the single four-barrel 396/375 and 427/425 hp Chevys."
I have a 396 Holley and it is the 780-CFM carb that was very popular back in the day.
Name:	01  RA V Carb.jpg
ID:	532316   Click image for larger version
Name:	02  RA V Carb.jpg
Old 02-17-2020, 10:14 PM
Yep Jim, that's what I was eluding to earlier. Those 780's for the Chevrolets were often referred to as 800 cfm carbs in a lot of literature throughout the decades. So there is a lot of confusion there. People still today refer to them as 800's.
Old 02-17-2020, 10:45 PM
First thing that pic of the intake and carb is not showing a RA V carb.The throttle arm is incorrect.Tom
