Old 02-15-2020, 09:54 AM
slowbird's Avatar
slowbird slowbird is offline
Default M/T ss radial tires?
Who here is running or has ran M/T SS radials? Im on the fence about buying a set. Need a DOT approved that works.
Old 02-15-2020, 10:07 AM
leeklm's Avatar
leeklm leeklm is offline
Darby had great results with them. I just bought a set of Hoosier "DOT" radials, but have not mounted them yet. I do not need them for street, and figured the hoosier will have more rubber on the ground since fewer tread cuts than the MT. Darby runs decent HP, so the MT does well!!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 02-15-2020, 10:17 AM
slowbird's Avatar
I talked to Darby, they worked great him, but his suspension is sorted out and has nice shocks. Just wondered how they are for others.
Old 02-15-2020, 10:53 AM
78w72 78w72 is offline
do you need the dot approval for actual street use or just dot approved for a racing class?
the m/t radial pro 275/60 are dot approved for racing but strangely are not street legal... every comment or review said they are the best m/t drag radial tire & work very well on all track conditions.
Old 02-15-2020, 11:02 AM
slowbird's Avatar
Want to drive to the track with them on. If i have to swap tires at the track ill just go with a radial slick
Old 02-15-2020, 11:14 AM
firechickenman's Avatar
firechickenman firechickenman is offline
I have a set. They work great for me. As good as the old ET Street Radial and the ET Street Radial Pro but I'm not making that much power either. Another option would be the ET Street R. It's supposed to be better than the S/S but not as good as the Pro.
https://mickeythompsontires.com/drag-tires/et-street-r
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
The Following User Says Thank You to firechickenman For This Useful Post:
Old 02-15-2020, 11:43 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Quick Time Pro's are a bad azz consistent tire!
Go fast, see Elvis!
Old 02-15-2020, 12:58 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I used them with very good results. My car had stock leaf springs and cheap generic rear shocks with CalTrac bars. Low 1.50 short times in a 3500 lb car.
Old 02-15-2020, 01:09 PM
slowbird's Avatar
Good info thanks.
The car we'll be putting these on weighs 4200lbs and gets high 1.5 60fts. It's just stock suspension with cheap shocks.
Old 02-15-2020, 03:14 PM
PAUL K's Avatar
Good info thanks.
So my info wasn't good?
Go fast, see Elvis!
Old 02-15-2020, 03:22 PM
slowbird's Avatar
Sorry, want to run a radial
Old 02-15-2020, 04:16 PM
leeklm's Avatar
Yep, not a radial but they got the job done on the 73 and was surprised at how long they lasted (strip use only in my case).
The Following User Says Thank You to leeklm For This Useful Post:
Old 02-15-2020, 07:41 PM
Mark G Mark G is offline
I run Hoosier Quick Times I drive on the street and race at the track .All track here have no radial tire prep.
Old 02-15-2020, 08:23 PM
Good info thanks.
I have used the old style M/T drag radial and the SS drag radial, now I have the pro drag radial. Still DOT but definitely not something I want to drive in the rain on. All 3 versions work best for me at 17 or 18 psi.
Old 02-15-2020, 08:28 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Good info thanks.
They are a decent tire. DXP street class runs those tires and have been high 4s at 140. That is on a radial prepped track. They should work for what you ar doing for sure.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 02-16-2020, 08:07 AM
taff2's Avatar
taff2 taff2 is offline
We have a street legal class here (Street Eliminator) that has to run E marked DOT tyres, the MT SS radial being the tyre of choice in 295 (or 315 if you have any old stock), quite a few cars in the 7 second range, one in the 6.90's on the 315. They only get around 10-12 good runs out of the tyre though, the tread wears very quickly and the tyre 'goes off' too.
Old 02-17-2020, 09:17 AM
Rob B's Avatar
Rob B Rob B is offline
We run them on the wife's car and love them. Car goes high 1.40's and never really had any issues with them hooking, even after a bunch of street miles. I was skeptical of them until I was seeing people go stupid fast with them. Our suspension is nothing fancy and the cars about 3500lbs. We use the 275/60/15's.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 02-17-2020, 09:30 AM
slowbird's Avatar
Thanks guys. Think we'll try the 295/65 ones and see how they work
