'72 Parts - Coil Bracket, Starter Bracket, Engine Bolts/Hardware
I need some parts for my '72 Formula.
I need the following: Timing Cover Long Bolts (6) Water Pump to Intake Long Bolt(1) Intake Manifold Bolts/Studs (10) Carb Bolts/Studs (4) Throttle Cable Bracket (2) Choke (1) Vacuum Valve (1) Fan/Water Pump (4) Crank Pulley (4) Oil Filter Housing (3) Thermostat Housing Bolt/Stud (2) AC Bracket to Intake (1) AC to Head Coil Bracket Rear Starter Support Bracket
1972 Formula 400 |
I think I have a coil bracket that was re-plated sitting around some where. I'll try digging it out.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
Hi
I have everything but the intake bolts
Scott68gto@comcast.net if you still have a need..... all oem ....... Scott |
Here is a detailed list of the hardware I need.
Not sure what bolts are used on the Fan Clutch, but I need 4 of those too. Also need a Coil Bracket: Water Neck 478144: Most of the original bolt heads should look like this: Bolts- 10- 5/16”x5/8” 1- 5/16”x1” 3- 3/8”x3/4” 10- 3/8”x1” 2- 3/8”x2” 6- 3/8” Intake Bolts 4- 3/8” Intake Studs with 5/16” threaded heads 1- 3/8” Water Neck Stud with 5/16” threaded head Nuts/Washers/Etc… 4- 5/16” Nuts (washer style nut) 2- 5/16” Washers 1- 3/8” Nut 3- 3/8” Washer 2- 3/8”x1” Steel Spacer (This is a round steel cylinder with a hole in the middle)
1972 Formula 400 |
i have a water neck pm me
I found the coil bracket and will take pictures later today......off to the parade.
Coil bracket with condesor clamp
Here are a couple of pictures of the coil bracket with the condenser clamp that I have. It has been re cad plated a few years back, and is very clean. Is this what you are looking for? PM me if it is.
thanks
super gent to work with
boxed up the dozen or so items as requested and ready to ship monday fast payment thanks again for your patience and purchase Scott |
