#81
66 GTO the frame was ground down and cleaned it was then primed and sprayed with black chasis paint.Then it was clear coated 3 time all though this is not 100 percent factory correct but i feel living up here in Canada some of our road are not the best this will give my frame some extra protection and I am happy with the look.
Thank you for the compliments Shawn
1964 Catalina 2+2, 389 Tri-Power , 4 Gear , 8 Lugs 1966 GTO, 467 Stroker Mid 11s 2002 Firehawk Vert, SOM , 6 speed, all the SLP Goodies 1968 Firebird Race Car,525 CU IAll looking for low 10 second passes! 1970 442, # Matching 455, 4 Speed W-25 hood |
#82
Goatseeker after a couple of conversation with a few of our pontiac racing brothers(Old Man Taylor,Hot Rod) my combo on a good day at sea level should push my GTO into the Mid 11s.Were I race in Alberta 3200 ft,with air most days @ 5000 ft I will be happy with high 11s the first couple of times at the track it will probobly be low 12s.Right now my engine is only about 75 percent of its full potential(HYD Cam Shaft,more porting on the heads ect) My car is a driver not a full race car,I know for sure i wont be embrassed on the street by a 5 ltr mustang or a Ricer.When some one ask me how much HP is my Car i will have no problem telling thems its over 500 hp.I would like to put it on a rear wheel dyno but i am not aware of one in edmonton wich is 3 1/2 hours away.
Shawn
#83
The body work begins
#84
Now the fun begins
#85
the fenders being done
#86
A little to much cancer for my likeing
#87
Replacement piece welded in
#88
Stll shooting for that july 1st completion ,should have paint and body complete in 3 more weeks then is the interior and all the little stuff,thank to every one who has helped me so far.
Shawn
#89
Shawn,
You are lookin' good! Making some serious progress. I see nothing except lack of traction to keep you from mid 11's @sealevel with that motor. You mention that it's a "driver", can you tell me about the short block? What connecting rods did you use? 4 bolt or 2 bolt mains? How fast do you plan to spin it (i.e. 6000rpm or more)? Thanks, Tim |
#90
Tim, I have a set of Draglites 15x8 with a set of Mickey Thompsons ET Street 26 inches Tall x 10 inches wide.Hopefully we should get some good Traction
#91
Tim I have a period correct 1966 421 H.O. 4 bolt main block. 455 nod pontiac stock crank,Eagle connecting rods,S.R.P. Pistons,Harland Sharp 1.65 Roller Rockers,Edelbrock heads that flow 320 cfm@ 28 inches of Water,Edelbrock RPM Intake, Holly 870 street avenger,My Cam is a custom grind from comp cams,If you want any more info just email me.
Shawn
#92
Just a few more goodies that i picked up in the last month or so a new Vacuum Gage and I also had my clock restored by the clock works(Top Notch Resto on the Clock Thanks Jerry)
#93
A picture of the restored Clock from the clock works
#94
Shawn,
Nice craftmanship and fine attention to detail. Les
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
#95
Thanks Les I can only hope that my 66 will look as nice as yours when it is finished
Shawn
#96
Got some more pics to show,the back trunk to back window panel has been removed and will be welded in by mid week
#97
Just took off the trunk to back window panel as it was to rusted .Should have the new one in by mid week every thing is comming along good.
#98
here is another pic of the trunk Panel
#99
here is a picture of the door that was fixed with a new patch
#100
here is the inside of the door patched up
