Old 01-10-2003, 11:59 AM
Rugratman's Avatar
Rugratman Rugratman is offline
I have one dash light, That will not come on.
The wiring system is the plastic clips with wires that go to the bulbs. Are these clip sets made any more ?
Can you wire them direct ?
Rusty
67GTO
........I'm just learning as I go.......
Rugratman's Avatar
Rusty
67GTO
Old 01-10-2003, 01:33 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
If you mean the twist in plugs that hold a 194 bulb yes they can be purchased. Thats what my 70 uses, not sure if thats what is in a 67 though?
Oops, guess not. I looked up a 67 gauge set on ebay to see one. Looks different. Looks like the snap in plugs like are in a clock or tach in a 70. I would go to an auto store and see what they have in the electrical section. theres quite a few different bulb plugs there usually.
GR-RRR!
[This message was edited by 428GTO70 on January 10, 2003 at 03:42 PM.]
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 01-11-2003, 08:38 AM
Rugratman's Avatar
Actuall the plastic clips clip on to each other in a sussesion. eacc clip the has a wire that goes to each bulb. I suppose GM's thinking was that you could keep adding on.
Problem is the circuit stops half way. I have tried re arranging them, No help.
I am almost ready to start spicing. My luck it will make it worse.
Rusty
67 GTO
Old 01-22-2003, 02:48 PM
saxit2me2 saxit2me2 is offline
I just finished putting new lights in my dash and I hated those plastic bulb holders that unsnap and swing down. they have a hot wire that connects all across the dash. is that what you have? I kept burning wires until I found one twist-on holder that had no bulb and was grounding itself. I also had a turn signal light that was not working. It was a mess but all was well once I found that one bulb holder that was grounding. I hope this is of some help.
