KRE or Edelbrock?
Which one are you using and why? The complete 455 I got has the low compression 4X heads so I am gonna buy one or the other. Cam will either be old faithful or stump puller I haven't decided yet.
I bought the JBP Edelbrock d-ports mainly out of convenience since their turnaround time and customer service/responsiveness is awesome. Of course, JBP doesn't sell the KRE's - seems one of the best shops to buy those prepped is SD. While they (SD) are also known for great CS, getting Dave on the phone or even email can be quite a challenge. After shipping, the e-heads may be a bit less if buying ported. I suppose you also have the option of buying the KRE's directly from Kauffman but I haven't seen where anyone here mentions them. If you are considering right "out of the box" your options are expanded.
All of what I've written above was based on d-ports (since you said KRE). The e-round ports are a no-brainer if you are considering round ports.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Dad bought the Edelbrock round ports from Kauffman, CNC ported. That was several years back before the Kauffman heads were offered. Like Grivera mentioned, I too had trouble getting a hold of Dave when I was looking at some options. No longer in California and back in Canada, I went a different direction. I don't think you could go wrong with any of the head choices out there. Depends on what you want to deal with. Pick your poison.
If the money plopped into my lap right now, I'd order the KRE's from Dave @ SD Performance.
From reading tuning details from various people, the KRE's typically require less tuning. In my experiences, that indicates a more efficient chamber design, and more performance. I've dealt with Dave numerous times over the last.... geez, maybe 15 years now? He has always been a pleasure for me to deal with, and I've never had a problem with anything he has done for me. I'll design my own camshaft, though :-)
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
If you are buying them too, then I would get ported round port E heads and use one of the recommended suppliers everyone here always mention, like SD, Butler and the others. All will recommend a cam and the rest of the parts that will work with their porting and set up. One thing I think I would change if doing it over, These new heads flow so well on the exhaust side that I would lean towards a non split pattern cam or even a reverse split with more intake duration. I bought from Butler and got lots of help with picking out everything, I had the headers already so I have d-ports. They have the heat cross over that round ports do not, but I will only use the car in the Summer anyway so not really needed.
73 T/A 455, 4speed |
I want to start off by saying my friends and I send a lot of business to both Kaufman and Butler for stroker kits and other parts, and really appreciate them both -- but when it comes to heads Dave gets the nod. Materials and workmanship are always top notch from Dave. I usually end up doing minor cleanup on the other's heads, and Dave's have always been ready to bolt on out of the box.
I haven't had any problems at all contacting Dave by email, and I can't really blame him for not taking the time to answer the phone. A one-man shop can either be chatting or working, and I know what I would choose. His email replies to me are usually time stamped pretty late at night, and that tells me he comes in after a full day in the shop and then hits the computer to catch up on inquiries.
I have as cast KRE d ports on my 455 straight from Kauffman. I looked at the edelbrocks as well and their slightly larger chamber and valvetrain setup for common flat tapper cams didn't mesh with my goals and they were about $150.00 more before any changes.
Going directly with KRE I was able to get the heads setup for the parts I was using and the turnaround time was quick. I wanted SD prepped heads but I wasn't in a position that I could really wait. Jeff Kauffman was great to work with, provided me a set of heads that I didn't have to touch and did everythi g he said he was going to, when he said he was going to do it.
Both. E-Heads worked by KRE.
if you're going to buy one of Dave's cams, why not run his heads too?
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
KRE's by SD here. Absolutely nothing wrong with them but after seeing the most recent Edelbrock D-port casting quality, I believe that Edelbrock makes a better quality head and I would have went with them had their new combustion chamber been out when I ordered by KREs. Truth be told, if I had it all over to do again from scratch, I would have went with the Edelbrock round port with the new chambers.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
How limited are my options for exhaust with the round port heads? Car is a 64 Tempest
I went with round ports primarily because my car originally came with round ports. All these heads offer excellent performance gains. I could have saved a ton of money by going with D ports.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
I've not heard of anyone else having that happen to them, but I still remember looking at that head when it came off! I'd love to see a direct comparison between the KRE and E D-ports.
When my father built his first 455, the Edelbrock round ports were the "go to" head at the time. There weren't any other choices, lol.
Today we almost have too many choices. The determining factor for me now just depends on the car, and which header or manifold I'm going to run before I decide on the type of exhaust port configuration. In my mind I like the round port stuff because that has always been synonymous with Pontiac performance. But can pose a problem in some applications. |
"...d-ports. They have the heat cross over that round ports do not, but I will only use the car in the Summer anyway so not really needed..."
If you want or need to use the exhaust heat crossover, the Edelbrock D-ports are the only choice. |
http://butlerperformance.com/c-12348...manifolds.html |
With that said, the few I have seen required more timing. I agree from the above statement that the new CNC chamber round ports would be an interesting head to use unported or just port matched. |
Have not run Edelbrock, but have had a set of 295 and 305cfm KRE dport from Dave. Delivery may take time, but worth the wait imo. Dave seems to like the kre d port for more flexibility, and I would have to assume he might have a little better profit margin with the kre.
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
I went with KRE's D ports, 310 CFM ported by Kauffman. Customer service was incredible, I had a problem with one of the heads and they picked the pair up, ported a new one and ensured it matched the remaining good one and sent me all the gaskets required to put it back together on their dime. This was almost 2 years after I originally bought them and had run them on my motor for over a year.
