Old 12-25-2012, 04:07 PM
judgemental's Avatar
judgemental judgemental is offline
Default 70 Judge engine/rear end code
This is the number from my engine. Is WT right for a 4 speed judge?
Stamping from rear diff, is XH correct for a 3:55 posi?
Old 12-25-2012, 04:21 PM
WT is not a Judge engine code.
The XH is a 3.55 posi ratio rearend.
Is this out of your car?
There should be a partial VIN down by the timing cover (passenger side)
Also the date code back by the distributor.
The partial VIN would match the car it came from.
Old 12-25-2012, 04:48 PM
steve v's Avatar
steve v steve v is online now
Should be a WS on a RA III, WW on a RA IV or WA on a 455.
Old 12-25-2012, 04:52 PM
This is the current engine and rear end in my Judge. Is the rear end code 083 XH, is 083 the julian date?
Old 12-25-2012, 09:11 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
083 is the Julian date code for the axle assembly.
XH = 3.55 Safe-T-Track Rear Axle
9799202 = 1970 rear axle casting #
19 = Julian Date code on pumpkin.
John
Email jbr69gto@gmail.com
My Website www.minnesota-muscle.com
Old 12-25-2012, 09:42 PM
Held for Ransom's Avatar
Originally Posted by GTO JOHN View Post
083 is the Julian date code for the axle assembled (March 24th).
19 = Julian Date code on pumpkin (when it was cast (Jan.19th)).
I like this a little better.
Old 12-26-2012, 01:58 AM
WT is the base code GTO 350 Horse -Manual- code.
And was also used in 1970 Manual Firebird 400.
ima guess its a 70 engine by EUN, and probably later date coded.
Have you heard this engine run ?
Kind of wondering about those cork head gaskets
Old 12-26-2012, 08:39 AM
I bought the car all apart they put the engine back together so it could be shipped. Never noticed the cork there
Old 12-26-2012, 11:02 PM
GTO JOHN's Avatar
Ah yes of course. Thanks for the tweek.
John
Old 12-29-2012, 11:08 PM
Vin # from engine
Cast date back of block Cant read dist #, what is the correct # for a 70 4 speed Judge?
Old 12-29-2012, 11:21 PM
If i'm reading the VIN right ( 201111478 )
That would be from a Canadian Built 70 GTO.
They didn't build Birds or TA's there.
Is your Judge a Canadian Built car - just by coincidence / curiousity ?
i guessed the date would have been much later than Oct 69
just don't follow EUN's close enough
Old 12-29-2012, 11:25 PM
BVZ
Yes its Canadian, cowl tag
Old 12-29-2012, 11:54 PM
Numbers off frame
Old 12-29-2012, 11:57 PM
I believe the trans and rear end are original to the car
Old 12-30-2012, 12:44 AM
GTO JOHN's Avatar
block vin 201111478
trans vin 201122534
block and trans not matching. What is the car VIN? Do you have the PHS documentation on the GTO?
John
Old 12-30-2012, 01:15 AM
John
Engine is not the original. I knew that when I bought it. Thr trans and rear end are original to the car.
Old 12-30-2012, 08:03 AM
lockec lockec is offline
Looks like the trans may be matching
Old 12-30-2012, 10:36 AM
This was a Canada built Judge sold in RI.
The WT distributor number would be 1111176, for the RA III it would be 1112010 (for manual tranny).
Can't really make out what yours shows in pic.
I'd say it's all there but the engine.
Cool that they had a Canada stamped engine to put in it.
(and possibly close to date matching?)
Old 01-06-2013, 08:50 PM
This is the dist that came with the car
Old 01-07-2013, 11:58 AM
Kenth's Avatar
Kenth Kenth is offline
1112089 is a 1971 400 2bbl distributor.
Starts 0°-4° @ 1700 rpmīs, 6°-10° @ 2000 rpmīs, 22°-26° @ 4600 rpmīs.
Vacuum advance 1115364 starts @ 6-8-in/hg, max 20° @ 13-15 in/hg.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
