70 Judge engine/rear end code
This is the number from my engine. Is WT right for a 4 speed judge?
Stamping from rear diff, is XH correct for a 3:55 posi? |
WT is not a Judge engine code.
The XH is a 3.55 posi ratio rearend. Is this out of your car? There should be a partial VIN down by the timing cover (passenger side) Also the date code back by the distributor. The partial VIN would match the car it came from.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
Should be a WS on a RA III, WW on a RA IV or WA on a 455.
This is the current engine and rear end in my Judge. Is the rear end code 083 XH, is 083 the julian date?
083 is the Julian date code for the axle assembly.
XH = 3.55 Safe-T-Track Rear Axle 9799202 = 1970 rear axle casting # 19 = Julian Date code on pumpkin. |
I like this a little better.
WT is the base code GTO 350 Horse -Manual- code.
And was also used in 1970 Manual Firebird 400. ima guess its a 70 engine by EUN, and probably later date coded. Have you heard this engine run ? Kind of wondering about those cork head gaskets |
I bought the car all apart they put the engine back together so it could be shipped. Never noticed the cork there
Ah yes of course. Thanks for the tweek.
Vin # from engine
Cast date back of block Cant read dist #, what is the correct # for a 70 4 speed Judge? Last edited by judgemental; 12-29-2012 at 11:18 PM. |
If i'm reading the VIN right ( 201111478 )
That would be from a Canadian Built 70 GTO. They didn't build Birds or TA's there. Is your Judge a Canadian Built car - just by coincidence / curiousity ? i guessed the date would have been much later than Oct 69 just don't follow EUN's close enough |
BVZ
Yes its Canadian, cowl tag |
Numbers off frame
I believe the trans and rear end are original to the car
block vin 201111478
trans vin 201122534 block and trans not matching. What is the car VIN? Do you have the PHS documentation on the GTO? |
John
Engine is not the original. I knew that when I bought it. Thr trans and rear end are original to the car. |
Looks like the trans may be matching
This was a Canada built Judge sold in RI.
The WT distributor number would be 1111176, for the RA III it would be 1112010 (for manual tranny). Can't really make out what yours shows in pic. I'd say it's all there but the engine. Cool that they had a Canada stamped engine to put in it. (and possibly close to date matching?)
This is the dist that came with the car
1112089 is a 1971 400 2bbl distributor.
Starts 0°-4° @ 1700 rpmīs, 6°-10° @ 2000 rpmīs, 22°-26° @ 4600 rpmīs. Vacuum advance 1115364 starts @ 6-8-in/hg, max 20° @ 13-15 in/hg. |
