Old 10-30-2013, 03:58 PM
RamAir's Avatar
RamAir RamAir is offline
Default Starter rebuild
I have the original starter out of my '72 LeMans Sport Vert that I would like to have reconditioned. Any suggestions as to where I should send it?
Old 10-30-2013, 04:58 PM
Held for Ransom's Avatar
PM member "stellar".
Old 10-31-2013, 01:46 AM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
Wow! My one owner survivor '72 GTO has an original starter that was built on the same day. It has a part # 1108495 and date code 2B22 1. Presently the starter is in my attic and a Delco Rebuilt is in the car. Eventually the original will go back in the car. My car came off the Pontiac, MI. line on March 1st. What day was your car built?
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
Old 10-31-2013, 06:57 AM
RamAir's Avatar
Car was built 04C in Pontiac, MI. It's a 350 cu in. My 72 400 cu in was built 04D in Pontiac, MI. I was considering reconditioning the starter to put in my 400, which has a re-man currently installed. I'm wondering if they're compatible?
Old 10-31-2013, 09:41 AM
tripower's Avatar
tripower tripower is offline
The 71 400 & 350 starters are different so I'm assuming that is true for 72 as well. The field coils may have a shunt on one the 400 unit. Solenoids may be different as well, they are on 71's.
Norm J
Old 10-31-2013, 10:01 AM
stellar stellar is offline
1108498 has low torque armature and fields have 1 shunt winding. 1108495 is high torque. It has bigger armature and different field windings. They will physically interchange on the car as a complete unit. You can use the 495 in place of the 498, but I would not recomend using the 498 in place of the 495.
The Following User Says Thank You to stellar For This Useful Post:
