Old 01-11-2014, 05:01 PM
RamAir's Avatar
RamAir RamAir is offline
Default Front Wheel Opening Flare removal
I started the front valance removal and repair process today (original plastic) and discovered the right flare is cracked at the front lower where the bolt goes through the hole. Are there just 3 screws that secure the flare to the wheel opening? 72 T/A
Old 01-11-2014, 05:07 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
There are two bolts securing it to the fender that have to be accessed from the engine compartment, one bolt at the bottom attaching it to the center spoiler, and three sheet metal screws attaching it to the wheel well opening.
The Following 2 Users Say Thank You to Dens71TA For This Useful Post:
Old 01-11-2014, 06:08 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Ditto for 73.
Old 01-11-2014, 06:20 PM
transam1972 transam1972 is offline
Default 72 Front Spoiler
Ramair....I am installing a repop of the 72 valance along with an oem front spoiler..I was wondering what length are your spoiler install bolts?...just a curious detail I am trying to find out...my car had a service replacement metal valance and they were to cheap to add the spoiler!...only if it happens to be convient thanks!!!....they may be the common 7/8'' thread length or perhaps longer?
Old 01-11-2014, 06:25 PM
RamAir's Avatar
I am going to clean up the bolts Monday and I'll take some pictures and measurements and let you know. They are all 'matching' and they're definitely the original bolts.
The Following User Says Thank You to RamAir For This Useful Post:
Old 01-13-2014, 01:51 PM
RamAir's Avatar
[QUOTE=transam1972;5105821]Ramair....I am installing a repop of the 72 valance along with an oem front spoiler..I was wondering what length are your spoiler install bolts?...just a curious detail I am trying to find out...my car had a service replacement metal valance and they were to cheap to add the spoiler!...only if it happens to be convient thanks!!!....they may be the common 7/8'' thread length or perhaps longer?[/QUOTE
7/8" length. Interestingly enough, the spoiler bolts are bigger then the valance bolts but they're the same 7/8" length
Spoiler Bolts
Valance Bolts
Old 01-13-2014, 02:56 PM
Default spoiler & valance hardware
WOW!!...Thanks Ramair!..the assembly manual shows 2 differant screws for assembly..but it is what I thought, it was assembled with the same common bolts (....314) as used on the fenders etc...since I had a metal valence installed, I determined that my 72 grill to bracket screw course thread hardware was what they probably used, and I am right!..those valance screws should match your grill to brkt. also...at the ADK Hardware website I was able to match them to 1969 Camaro grill screw...thanks for your help on this..I am good on all my front end reinstall!!
Old 01-15-2014, 02:16 PM
Default POLY. VALANCE
RAMAIR...I was wondering if your poly. valance has a hole for a bolt to go through when the parking lights are removed?...in other words,when you remove your parking lights, does the valance have a bolt hole so the valance secures itself to the small bracket located on the front inside of the fender?...does the bracket have a u nut or not?...I am trying to determine if 1972 fenders used that bracket or not to secure the poly. valance to the fender?...obviously a poly valance mounts also to the lower edge of the front bumper (one way to tell a 71 to 72 bumper,72 has holes drilled underneath)..your help is most appreciated!!
Old 01-16-2014, 07:49 AM
RamAir's Avatar
It does not, there are 8 bolts that attach the valance.
Old 01-16-2014, 09:24 AM
Default poly valance
thanks Ramair!!..interesting...so for 1972 that lower front fender bracket serves no purpose....it is only used for the metal valance
Old 02-04-2014, 01:14 PM
RamAir's Avatar
Default Valance & Wheel Flares
I am putting my repaired front valance and wheel flares back on. I am missing a couple bolts for the access panel. Where would be my best source for these?
Old 02-04-2014, 02:53 PM
Default bolts
RAMAIR...I have used & repop if you need them, a good source for repop is Inline Tube or the E BAY,..many different head markings to choose from
Old 02-04-2014, 03:17 PM
RamAir's Avatar
Thanks Glen! he's sending me spare bolts in today's mail
Old 02-04-2014, 04:27 PM
Default BOLTS
they are on the way!!
The Following User Says Thank You to transam1972 For This Useful Post:
Old 02-04-2014, 09:55 PM
Default repop vs. orginal hardware
Name:	original & repop hardware.jpg
Name:	original & repop bolts.jpg
Name:	fan shroad & front air dam mounting hardware   repop.jpg
Name:	original & repop screws.jpg
Name:	repop 1972 455 h.o. head bolts.jpg
ID:	351876these are just some of the original style GM bolts available...door hinge bolt,1/2 & 7/8bolt,fan shroad & front air dam & u-nut that are available...I am not a head bolt markings kind of person and I do save the originals...its just that when I finally install my new painted front sheet metal I would like new hardware...ADK HARDWARE is a good source for original style cage nuts and other unique bolts...the head bolt kit I purchased just for a new negative battery cable mounting bolt...although I see that they are now offered separately on EBAY,it figures!
Old 02-15-2014, 04:22 PM
RamAir's Avatar
Default Valance & Flares
I got the repaired Valance and fender flares reinstalled today.
Old 02-15-2014, 05:39 PM
Default NICE!!!!!!!
looks fantastic!!!...I love seeing pix of other 1972 TRANS AMs!!!..careful, everyone will want to buy your valance!!!
Old 02-15-2014, 05:41 PM
RamAir's Avatar
Thanks, the bolts you sent me worked perfectly!
