Old 06-29-2022, 05:13 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
David if you're running any of the Hayden heavy duty clutch fans, I would recommend doing the clutch spring modification linked to by mgarblik and grivera. It was worth about 10 degrees on my junk. Maybe better on yours?
  #1042
Old 06-29-2022, 05:30 PM
max 93 max 93 is offline
Did you ever tell us the diameter of the water pump pulley?
The Following User Says Thank You to max 93 For This Useful Post:
  #1043
Old 06-29-2022, 06:54 PM
64speed's Avatar
64speed 64speed is offline
GRIVERA sent me a modded one. We are gonna revisit it with this bigger fan.
  #1044
Old 06-29-2022, 06:56 PM
64speed's Avatar
I will have to measure but CVF assures me it’s the best they make. I am certain that it’s an air CFM issue. It almost overcools on the road but does not like to idle
  #1045
Old 06-29-2022, 07:00 PM
Just because it’s “ the best they make” doesn’t mean it’s the best for your car
  #1046
Old 06-29-2022, 07:43 PM
Just for reference, My factory ac pulleys are about 5-3/4” for the water pump and 8” for the crank. If you don’t have a similar pulley ratio, that may be the problem.
  #1047
Old 06-29-2022, 08:41 PM
64speed's Avatar
So I have an alternator a power steering pump and a sanden AC compressor. What setup should I be looking for? CVF says I have the hi flow matched pulley set
  #1048
Old 06-29-2022, 09:08 PM
tom s tom s is online now
Small water pump pulley is important!
  #1049
Old 06-29-2022, 09:25 PM
I was looking at CVFs website and see that they say the water pump pulley is 8” and the high flow crank pulley is 7.4”. I’m not sure that I was looking at the same setup that you have though.
  #1050
Old 06-29-2022, 10:53 PM
68WarDog's Avatar
CVF says I have the hi flow matched pulley set[/QUOTE]
You may have to call BS on CVF, as I requested the high flow crank pulley, but in the std( wp- ps and alt pulleys) I received the 6.25 crank pulley . I will be changing it out for either the 7.4 or 8" before putting this engine into service.
Measure the unit and not take CVF word.
  #1051
Old 06-30-2022, 06:09 AM
So you picked up some vacuum with adjusting idle speed, that's a positive sign.
You are running your vacuum advance on full time manifold vacuum, correct? You need to know what your total advance is at idle. You should have over 20 degrees at idle, where you need it.
You did set your timing at idle with the vacuum advance disconnected, right?
  #1052
Old 06-30-2022, 06:46 AM
tempest1964's Avatar
Measure the unit and not take CVF word.[/QUOTE]
This!
The Following 2 Users Say Thank You to tempest1964 For This Useful Post:
  #1053
Old 06-30-2022, 12:46 PM
He's running the 8.0" crank pulley and the 6.2" water pump pulley, overdriving the water pump 29%. Pulley ratio is not the problem
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
  #1054
Old 06-30-2022, 01:11 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Do you have one of these or equivalent? https://www.summitracing.com/parts/h...yABEgK3UvD_BwE
If not, get one.
  #1055
Old 06-30-2022, 01:17 PM
grivera's Avatar
grivera grivera is online now
If not, get one.
That is what I sent him with the spring mod already done
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
The Following User Says Thank You to grivera For This Useful Post:
  #1056
Old 06-30-2022, 05:53 PM
JSchmitz's Avatar
Roger that. Nothing better, that I've found, for severe cooling needs. What do you think cools my 3/4 ton GMC truck? A big a$$ engine driven fan. I didn't have to do a thing to the clutch on my GTO. Worked flawlessly right out of the box. You could hear it engage and roar. Would show on a timeslip if it kicked in at the track. Don't recall exactly how much. It puzzled me for a while. lol
The Following User Says Thank You to JSchmitz For This Useful Post:
  #1057
Old 06-30-2022, 06:44 PM
64speed's Avatar
Talked to Derale. Ordered the 17118 and gonna use it with the fan clutch I got from Grivera. I am also gonna take the car to my friends shop that races a Pontiac when I have some money to pay him and see where we are.
  #1058
Old 06-30-2022, 08:38 PM
TB1's Avatar
TB1 TB1 is offline
Not to be the the bearer of bad news but the 17118 will hit the fan shroud unless you sold it, I saw it up for sale the other day? The 17117 will fit without interference and proved to cool my car just fine. I initially bought the 18" thinking no problem with the shroud but no luck, tried moving in around but didn't have the clearance and as soon as the engine torques over its a mess.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
  #1059
Old 06-30-2022, 08:48 PM
grivera's Avatar
Originally Posted by 25stevem View Post
Here is a issue that may be a big part of your problem and forgive me that it just came back into my mind.
If your running a Edelbrock intake they have a big potential problem with the water crossover.
That being the opening in each side of the cross over is at least 1/4” smaller all around( circumference) then the outlet in each head!
This makes for a massive restriction and when I gasket match a Edelbrock intake it’s the first thing that I go after and gasket match!
I would be willing to bet that if you address this your hot running issue is reduced by 75%, if not completely.
Is this proven to help with cooling? If so I will do mine as I have a separated x-over in my RPM intake.
Will Rivera
  #1060
Old 06-30-2022, 09:28 PM
64speed's Avatar
Do you have the small radiator?
