#1741
Old 11-05-2024, 12:05 AM
What’s an aero coupe?
1986 Grand Prix 2+2…..
ID:	642361   Click image for larger version
ID:	642362   Click image for larger version
  #1742
Old 11-05-2024, 12:30 AM
Keysup Keysup is offline
1986 pontiac grand prix 2+2
  #1743
Old 11-05-2024, 12:50 AM
Monte Carlo did that aerocoupe too.
  #1744
Old 11-05-2024, 02:09 AM
I’m showing my age. I still think of an 86 as a new car. Why would anyone want to restore an almost new car?
I recall seeing a few of the aero Monte Carlo’s around back then but I never saw a GP aero in person until recent years at shows.
1969 Cat (3 Cvt’s & 2dr ht)
1969 Bonnie Cvt & 2 wagons
Old 11-11-2024, 06:51 PM
Yes. It’s only 38 years old for crying out loud.
  #1746
Old 01-12-2025, 10:38 PM
stevesbirds stevesbirds is offline
Default Pulley for 63 421 SD
Asking for the moon here but anyhoo, trying to track down correct harmonic balancer and alternator upgrade pulley that is stamped steel and correct offset is pretty tough.
  #1747
Old 01-12-2025, 11:35 PM
turbo69bird's Avatar
I feel the same thing. Anything 86 87 is forever a new car to me
960 HP @ 11 psi, 9.70 at 146.
  #1748
Old 01-12-2025, 11:38 PM
Originally Posted by 242177P View Post
Aluminum hoods. 65-67 and 68-70 GTO. 70-76 and 77-81 Trans Am. I doubt it would be quite as simple as slipping a different sheet into the pile, but they're already stamping steel ones. Ah-loo-min-E-um.
Someone should know the answer to that since Pontiacs did make alluminum parts for cars previously running steel.as did other makes. Can’t be that hard or they wouldn’t have done it .
  #1749
Old 01-13-2025, 11:14 AM
Shiny Shiny is offline
Forum members have gotten together and done this with a few small items. And you are correct, these days, if you have the CAD file, you can get most anything replicated for a reasonable cost assume it doesn't involve manufacturing techniques that are complex or no longer use.
Simple parts made of uniform metal, or plastic are typically doable, but combined items like for instance pillar post covers that are stamped metal, foam and skinned with vinyl it gets way more complicated for us DIY'ers to do.
I remember you started developing a digital library of CAD models for parts for your own car (engine first?). At the time, I thought it was a huge labor of love and I've always envied your skills and enthusiasm. How far did you get before the move took over your spare time?
Too bad the original engineering drawings are not freely available. I know some are out there and many on here even generated some of them, but how cool would that archive be?
And I agree on the complexity challenges. Even reproducing "simple" parts would require all the lost skilled artisans when they need injection molding, sheet metal, or progressive die tooling. And matching colors would be a nightmare, as I expect a lot of the pigments and dyes used 50 years ago are long gone.
The last product I worked on before retiring needed some highly-stressed, functionally-critical coil springs. We were working with a highly competent manufacturer and it took us about 4 passes before they could tool a simple spring to deliver what we needed. Everything sounds easy until you do it.
Mike
  #1750
Old 01-13-2025, 01:40 PM
I’d like to see the 69 bird 400 baffle repopped
  #1751
Old 01-17-2025, 06:05 PM
SD73's Avatar
SD73 SD73 is offline
2 Port 72-74 carb Vacuum Fitting with the correct tapered threads.
Name:	Carb Fitting.jpg
  #1752
Old 01-18-2025, 09:17 AM
mgarblik mgarblik is offline
From what I have read about the aluminum pieces for the early Pontiacs, it was a difficult process with an extremely high scrap rate. The parts were stamped usually on a Saturday, first shift, by the craftsmen with the most experience operating the presses. The aluminum required different techniques and pressures to avoid tearing and to still get the crisp feature lines they needed. The dies used were for the steel parts and did not have the features in them to produce aluminum parts in great quantity. If I remember correctly, the scrap rate was something like 1 usable fender or hood for every 15 pieces stamped. So it's not a slam dunk simple deal.
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
  #1753
Old 01-18-2025, 09:40 AM
...If I remember correctly, the scrap rate was something like 1 usable fender or hood for every 15 pieces stamped...
  #1754
Old 01-18-2025, 11:51 AM
I'm surprised they could get any aluminum parts off steel tooling.
If they got 1 out of 15, they probably had to manually finish them with some creative bodywork.
Just the springback of aluminum will be 3 times steel because of the modulus.
Here's a great article comparing properties and how they affect forming:
https://www.metalformingmagazine.com...l-and-aluminum
Mike
  #1755
Old 01-25-2025, 04:41 PM
INchief INchief is offline
Default Gusher Tubes 287 V8
I would like to see the gusher tubes become available for the 287 V8.
