I have been reading old threads and posting some here and there while I develop my build, I think I’m there now. The car is a street and highway cruiser only with A/C and power brakes, needs to have good manners. I’m a stock performance type of guy. But want it to pull all the way to 5500.
I am looking for recommendations for both HFT or HR and springs needed. Here’s the combo: 67 LeMans 400 .040 4” stroke crank New 6.625 rods AutoTec Pistons (dished to 9.5/9.6 compression) Stock 670 heads Stock 68 iron intake Rebuilt 78 Qjet HO manifolds with 2.5” pipe 2004r with a 2200 stall 3.55 LS with 27” tires Let me know your thoughts and as always I appreciate your insight.
The More People I Meet, The More I Love My Dogs! |
I guess you did not like any of the answers you got before?
I was working through what I wanted to build and gathering information. And I don’t believe you ever offered a cam selection when I asked
Stump puller.Tom
Summit 2802 for HFT for HR none recommended. For springs you need to know installed height to properly pick. When you have that info contact Butler Performance and they will recommend a set
The Following User Says Thank You to Jay S For This Useful Post: | ||
Sorry. I thought you did.
There’s been so many of them as of late! Here’s some recommendations that will not fail you duration wise as long as you have a minimum 9 to 1 compression a long with the rear gears Lift wise with stock 670 heads installed height your good to .460” lift with fresh springs . I would try and run between.450” and .500” lift since that will help make torque and improve throttle response. If you’re not going to have the minimum 9 to 1 compression then pick a car of less duration. On the street it’s best to be a tad under cammed then over.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Your 4” stroked 400 with 670 heads and HO exhaust manifolds is essentially a stock 1967 428 HO.
Stick the manual trans 390 hp 428 HO cam in it. Use the factory 068 and spice it up with some stamped steel RAIV 1.65:1 rockers. Be just fine with stock 1.5:1 rockers too. I ran that setup on my last daily driver 455 topped with a ‘66 Tri-Power exhausting through ‘67 HO manifolds and it ran past 5000 rpm no problem. https://forums.maxperformanceinc.com...22&postcount=4 99.9% of the time you won’t be above 3000 rpm so why put some big cam in it?
The Following User Says Thank You to b-man For This Useful Post: | ||
You might look at the Bulter RAM AIR Series HR cams if you want stock type performance like described. The 068 and 744 version only have .45” lift and look like they would be easier on parts than the off the self HR cams.
I wouldn’t be very interesting in running any kind of new hydraulic flat tappet cam unless the cam was Nitrided. Even a little 068 replica. By the time that is added to the cost, and new HLJ lifters now cost well over $200, running a new HFT is not really a cheap option these days. Quality seems to keep getting worse on flat tappet cam components. I did a cam to replaced a 068 with 1.65 rockers in a low 9s compression 455. It idles about the same, and drives the same but seems to have another 40 HP. The car has 3.07 gears and A/C. It was a Bullet HFT. I have very nice used 224/230 HR cam like Tom linked in that thread.(432HP). It is just sitting on the shelf here if you want a cheaper HR option. I bought it because it was going to cost just as much do to a similar HFT cam. I have since went with a bigger cam. If your hiring stuff done, or put a value on your time, and choose a cam that needs the inner springs reinstalled after break in, that gets you part way to the extra cost of a HR cam. That 224/230 cam takes a bronze or composite distributer gear. The Howard’s I listed uses a stock gear, and is actually a little gentler profile even though it has extra lift. The Howard’s is a better profile IMHO. I would use Crower 68405 springs set up at either 1.6 or 1.62” IH with all those HR cams. With longer valve I would use a negative .050” valve lock and shim them to where you want. Last edited by Jay S; 01-19-2025 at 10:10 AM. |
Thanks Jay. I have a 702 Voodoo but thought it might be a little small after talking to the guy at Bullet. I have a set of HLJ lifters too.
Advertised Duration (Int/Exh): 262/268 • Duration @.050 (Int/Exh): 219/227 • Gross Valve Lift (Int/Exh): .468/.489 • LSA/ICL: 112/108 • Valve Lash (Int/Exh): Hyd/Hyd • RPM Range: 1300-5500 Quote:
The More People I Meet, The More I Love My Dogs! Last edited by ponchjoe; 01-19-2025 at 11:02 AM. |
Thanks Bman, that’s a very similar build
![]() Quote:
2802 would run great on that engine. Get some old lifter resurfaced and run it.
I´m running a true #744 cam in my newly built 1965 421 (4.16" x 4.00") with #64 heads with used #48 heads valvesprings. 1966 Tri-Power, TH400 and 3.07 gears in the 12-bolt rearend.
Runs awesome with an exhaust note thru the Pypes 2.5 system w/14" street mufflers at idle to die for. |
The Following User Says Thank You to Kenth For This Useful Post: | ||
I came across this Comp HFT, is it too hot for this combination?
RPM Operating Range: 2,000-6,000 Cam Type: Hydraulic Flat Tappet Camshaft Series: Drag Race Camshaft Gear Attachment: 1-Bolt Usage: Street/Strip California Proposition 65: WARNING: Cancer and Reproductive Harm P65Warnings.ca.gov Advertised Intake Duration: 276 Advertised Exhaust Duration: 284 Intake Duration at .050 Inch Lift: 228 Exhaust Duration at .050 Inch Lift: 236 Intake Valve Lift: 0.52 Exhaust Valve Lift: 0.52 Lobe Lift Intake: 0.316 Lobe Lift Exhaust: 0.316 Lobe Separation: 110 Intake Centerline: 106 Valve Timing Lift: 0.006 Exhaust Close ATDC: 28 Intake Open BTDC: 32 Exhaust Open BBDC: 76 Intake Close ABDC: 64 Lifter Style: Hydraulic Flat Tappet
![]() Quote:
![]() Quote:
I wish the 703 was available (well, Edelbrock says they can grind one still) I thought it was perfect. The Crower 60916 may be a thought too. INT/EXH - Dur @ .050” Lift: 221°/229° RR: 1.5/1.5 Gross Lift: .455”/.470” LSA: 112° RPM: 2000 to 4800 Redline: 5300
I would do the 60916.
Thread Tools | |
Display Modes | |
