![]() Quote:
I think a Summit 2802 would be better than a 60916 with 670 heads and a 4” crank. The 60916 would have been a good choice if you had a later open chamber head, 3.75 crank, or less compression with the 4”.
Cliff agreed with this also. Is the a HR similar to this in Howard’s?
The More People I Meet, The More I Love My Dogs! |
Yes
Yep. That is it. Howard’s also has that 2 profiles with less lift in a custom grinds. They have less lift and duration over the nose, seat timing and .050” timing are the same.
Any thoughts on this cam and Powell Machine in general? Anyone use one? Will it work in my combo?
Thanks https://www.powellmachineinc.com/pro...lic-roller-cam
It’s too much cam for 3:55 rear gears and once again that over .500” lift needs the valve train to be set up for it.
In any 400 motor that Pontiac placed the RA IV cam in your where mandated to also have 3:90 rear gears and NO ac. Your 428 is only 8% larger then a 400 so you would still want to have 3:73 rear gears to run that cam. Do as you will, I myself am tired of trying to guide you.
The Following User Says Thank You to steve25 For This Useful Post: | ||
![]() Quote:
No need to reply if you are “tired of trying to guide me,” then. I’ll figure it out with plenty of others input. PY is a great source information (but not the only) and just like the cam companies I’ve contracted I’ve gotten a range of information to choose from. Peace out man, unsubscribe.
The More People I Meet, The More I Love My Dogs! Last edited by ponchjoe; 02-02-2025 at 09:46 AM. |
You would have to talk to Powell and ask him about that cam. It might be a good choice, but there is not enough specs shown to really say if it would work well without talking to him. The stock converter you want to run would likely not be very ideal with that cam, but the extra low first gear in that 4 speed auto would help. Powell has tons of YouTube videos with pretty down to earth cam tech.
![]() Quote:
Making a cam decision for someone that only builds a motor every 5-10 yrs is hard. I want it to sound as good as it can too and the RA4 sound is hard to beat. I’m thinking something more like the RA 3 cam fits better though. I get confused with the differences in HR and HFT numbers
The More People I Meet, The More I Love My Dogs! Last edited by ponchjoe; 02-02-2025 at 09:56 AM. |
Powell has a ton of content on YouTube, he’s done a lot of videos on HFT lifters when he was resurfacing them. He’s moved away from that service according to his videos but seems very knowledgeable so I would call him as well to get his input.
The Following User Says Thank You to 67Lemons For This Useful Post: | ||
Most roller cam profiles have more area at higher lifts where the piston speed is higher. You can run a bigger cam compared to a HFT and still have the similar idle with more power.
The Following User Says Thank You to Jay S For This Useful Post: | ||
I ran an old comp 268h cam in my firebird back in the late 80s with 670 heads and 410 gears. it was a daily driver with an old q jet on it ran 13.70s at the track. just don't over think it....
1970 firebird, 468, e heads, |
The Powell cam is not by any means large. It is not much different than that Howard’s HR cam I suggested. But you would need to call him, I am guessing if you asked him he would suggest a slightly smaller cam than that.
Thanks guys, decisions decisions…
Have Bullet grind a Ultradyne 280/288 HFT on a 112 or a 288/296 on a 112.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
#38
#39
All I am
Saying Joe as others are alluding to here is that even with a 5 speed if a mistake has to endured, cam wise it’s better to have a smaller one then too big, especially if your shelling out the bucks for a hydro roller.
#40
230-240 on a 113 would not scare me at all in a 428.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
Thread Tools | |
Display Modes | |
