Originally Posted by 61-63
Here are the pictures. You can see the square tubing frame bracket I should have made it out of angle iron. On '61/'62 cars the bracket welded to the axle tube is square at the bottom and the sway bar mount mounts to it without any problem but on '63/'64 cars the bottom is angled and you have to weld a piece of triangle shaped plate to it to make it square. The pictures are of a '63 and that plate has been added to that bracket.
That's the bar I put on my 61 10 years ago. Fab Craft, Hardest part was drilling the frame. I also put on the tube type rear arms, all four, with hard bushings and Bilsteins all around. Car rides sweet and straight.
