Old 07-06-2014, 01:39 AM
kevin.1 kevin.1 is offline
Default Summit Discount Codes
Here are some 10% discount codes for Summit Racing (got these from Hot Rod Power Tour):
1) ZH10922678
2) ZH11920658
3) ZH12030606
4) ZH15134636
All codes expire 7/9/2014
-Kevin
Old 07-06-2014, 10:04 AM
T.D.Vick's Avatar
T.D.Vick T.D.Vick is offline
Thanks Kevin! The first code saved me $175!
'80 Grand Lemans
Was 301 C.I. Will be bigger soon.
00 GTP NBM / Graphite, Stock
Sold Aug. 2011
70 GTO Black / Black TH400
460 CID, 542 FWHP, 580 FWTQ
(Sold, Fall '09)
04 GTO Black / Black M6
Back to bone stock and sold, fall '05.
Old 07-06-2014, 10:30 AM
firechickenman's Avatar
firechickenman firechickenman is offline
Thanks Kevin! Saved $39. I used code #2.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 07-07-2014, 07:42 AM
AG's Avatar
AG AG is offline
How do you use the codes? Online or over the phone?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 07-07-2014, 09:50 AM
Should be able to use them either way. I always order online and enter the code in the "gift card or summit bucks" box and the date (in this case 07/09/2014) in the "issue/expiration" box.
'68 Firebird
Old 07-07-2014, 10:09 AM
AG's Avatar
AG AG is offline
Tried all 4 numbers and got this error message, "The gift card number (or coupon) you've supplied is either invalid, has an incorrect expiration date, or has not been shipped. Please check the numbers and expiration date you entered to be sure they were typed in correctly." I triple checked the expiration date.
Old 07-07-2014, 10:39 AM
Sounds like they've all been used....each one is only good for one use.
'68 Firebird
Closed Thread
Thread Tools
Display Modes
