Repo 70-72 Shaker, Anyone Here Use One?
I need to replace the shaker on my '72 as the plastic part is damaged beyond repair. I see Ames has a fiberglass replacement that you need to rivet to your old steel retaining ring part to for about $140.
I also see that the parts place has a complete functional shaker minus the solenoids for $300. https://www.ebay.com/itm/1970-76-Pon...p/270925479666 Has anyone used either one with good results? Thanks! |
Don’t even consider the parts place unit. Total junk
Craig can work miracles
Sent from my iPhone using Tapatalk |
I ran the fiberglas unit on my fake 71 - works/looks fine.
Mine is from NPD, very minor smoothing but mine was good. I used the rivet look alike small bolts for the reinforcement piece. I wasn't after anything stock exact, I opened the flap area/screened it and bonded in the blocker kit. if its a museum car you wouldn't want it as the underside shows the fiberglass layup.
Npd
The one pic white shows where I had to do some very minor filler and smoothing
Thanks for the pics Judge3. On your second pic is that a reinforcement molded into the top or just an air filter element laying in there?
2nd pic. got it. repop reinforcement piece, attached with rivet look alike small bolts/nuts from firebird central.
if your talking about the blocker kit, you epoxy on a supplied air filter composite plate. nice set up I like it. couple pics there before I epoxy primed it all. I did also epoxy all the sides after the pics were taken. no air gaps. fabbed my own mount plate for the screen, welded on nuts, epoxied it in. Last edited by JUDGE3; 12-20-2023 at 11:01 AM. |
one pic you can see the composite plate the air filter sits in. to the right you can see the clip is up.
slide the air filter in to holding brackets in the front (you cant see) then sit it in and place the clip(s) down, one on each side (you can see the one). Last edited by JUDGE3; 12-20-2023 at 11:01 AM. |
Gotcha. Nice job with the filter element, looks like it was born that way.
repro
Those early shakers were handy, shame GM decided to cast them shut. The bizarre years of shut hood scoops and shakers. All for looks, nothing for performance or reason for being there. |
A pity that GM came up with a new part number for the 1973-1976 shaker with those conspicuous mounting tabs, rather than the already existing parts with say the solenoids absent, and a new insert to keep the still hinged flap door stationary, or even re-programed solenoids to keep the flap door shut until say some higher speed if that would have worked with the noise standards.
Notably Pontiac equipped its 350 cid GTO for 1974 with a functional shaker.
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads 1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455". What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere? |
need a replacement GM shaker?
I have original un-restored Shaker that is complete. It is blue. Will need re-finished. Please email daveclark.uts.gmail.com. if interested and I can send photos. I purchased years ago and was told off a 1972. $1,000.00
David Clark 1972 Trans Am Blue 4sp 1973 Grand Prix Blue 400/Auto/Bench 1974 Trans Am Blue 400/Auto 1979 Trans Am Brown 301/Auto |
GM had to close them due to government drive by noise requirements. Damn government.
Email sent
