OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-19-2019, 12:57 PM
Hokie1984 Hokie1984 is offline
Default Umbrella Seals
So I am gearing up to install new seals on my cammer. Recently rebuilt the motor but experiencing some smoke especially on startup. I read that others put these umbrella seals on both the intake and exhaust. First can this be done and what type of seals have worked best on these engines. I’d rather not pull the head.
Old 08-19-2019, 06:21 PM
Jeff Hamlin's Avatar
Thumbs up
I went with Vinton Seals which is the way to go IMHO.
You really only need to machine the Intake side for these, Its overkill for the Exhaust side.
Old 08-22-2019, 03:05 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
If you are not going to machine the guides, you can only use the OE style umbrella seals on the intakes, nothing on the exhaust.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
