Old 09-09-2019, 08:33 AM
Half-Inch Stud's Avatar
Southern ingenuity?
Old 09-09-2019, 04:40 PM
sdbob sdbob is offline
Never seen that before. I just staked them or tapped them. Funny he didnt use ' wooden nickles'.
Old 09-09-2019, 05:57 PM
dmac dmac is offline
Originally Posted by PunchT37 View Post
It was prolly running on 1/2 gal plastic bottles of Bourbon before that.
I think that's what the mechanic was prolly running on.
Old 09-09-2019, 06:38 PM
KEN CROCIE KEN CROCIE is online now
Pontiac Performance Author
judging by the number of stake marks, the engine has been rebuilt many times and they just ran out of room for more staking.
Old 09-09-2019, 10:44 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Reminds me of hot rodding in the earliest days...fix it with what you have on hand. You don't likely have enough $$$ to get to town, let alone buy something to fix it.....
Shut it off
Shut it off
Old 09-09-2019, 10:58 PM
64speed's Avatar
64speed 64speed is offline
Reminds me of a guy I know who lost the fan studs out of the old waterpump on his Chevy 350 he was building. Time came to button it up an no studs. Everything was closed, it was a Saturday night and SC blue laws used to only allow grocery and hardware stores to be open on Sunday. He JB welded the fan clutch to the face of the pump and let it sit over night. Lasted about an 1/8th of a mile
Old 09-10-2019, 01:24 AM
dataway's Avatar
dataway dataway is offline
Well ... in the final analysis .... it appears they worked.
Old 09-10-2019, 02:01 AM
242177P's Avatar
242177P 242177P is offline
If those plugs really wanted to leave, I don't think those rivets could've stopped them.
Looks like they were already being kicked around by the timing chain too.
Old 09-10-2019, 02:05 AM
STEELCITYFIREBIRD's Avatar
That's the other pink that stinks!
With this level of hacking, it would be VERY wise to do a full dis/reassembly....and score yourself fitycent !
Old 09-10-2019, 11:36 AM
dataway's Avatar
Also strange that someone that would know enough to know that they needed to be retained, would retain them in that fashion.
Old 09-10-2019, 01:06 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Looks like a face with crossed eyes.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
The Following User Says Thank You to gtofreek For This Useful Post:
Old 09-10-2019, 04:01 PM
Joe's Garage Joe's Garage is offline
Default Low-budget rebuilder
Only cost him 50 cents to fix it.......
Old 09-10-2019, 10:27 PM
NeighborsComplaint's Avatar
Ad said he had a half a buck in the shortblock rebuild..
Triple Black 1971 GTO
Old 09-11-2019, 09:56 AM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Makes Everyone else look like Chip Foose!
Let's make welfare as hard to get as Veterans benefits!
Old 09-16-2019, 05:19 PM
406TT 406TT is offline
Originally Posted by TCSGTO View Post
Looks like they tried peening them in with a railroad spike then went full on Larry the cable guy on it.
I like the lettered rods, I guess they were dyslexic though
The rods look fine to me. 4 sets of 2. Starts at A from left to right. You see a rod with a letter, then a rod and no letter. Then repeat. Example posted below.
A-
C-
E-
G-
You can see what looks like A C E & G on 4 rods which are #1, 3, 5, & 7 starting on the leftmost rod. That's in the correct order of A b C d E f G h. So the rods look fine to me unless I'm reading those letters wrong.
Old 09-16-2019, 05:42 PM
John Milner's Avatar
John Milner John Milner is offline
Except that the rods are on backwards. Those oil holes in the rod should point towards the camshaft. I honestly am not sure how they got all of the pistons in with the rods pressed on backwards.
Old 09-16-2019, 05:45 PM
thepontiacman's Avatar
Wow, Just when you thought you had seen everything.
I disassembled a 455 once to find the thrust bearing on #1 main cap.
  #38
Old 09-16-2019, 05:59 PM
Reminds me of a story someone wrote into Hot Rad magazine about....This prospective engine builder marked all his #6 rod caps with a line at the bottom of the six...........so nobody would get it mixed up with a 9...
Shut it off
Shut it off
  #39
Old 09-17-2019, 11:17 AM
OG68 OG68 is offline
Must have been Ferrari owner.
2007 Cadillac SRX
Old 09-17-2019, 02:44 PM
SRR's Avatar
SRR SRR is offline
Once pulled apart a 400 that had 1.66 exhaust valve in 1.77 holes...cam bolt was falling out, all bearings were showing copper and the lifters ticked like hell. Was sold as a "Turn key" ready to run engine.
Another engine had been running hot so decided to replace the core plugs so we could flush the block. Someone had changed the plugs by pushing the old ones into the water jacket along with a small screwdriver. Tons of sediment came out of that one.
― Calvin Coolidge
Thread Tools
Display Modes
