Old 11-19-2019, 01:13 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 68-72 GTO Le Mans windshield channel repair
Anyone tried to cut out and weld in these repair panels Ames offering ?
Any pics or and feedback ?
A friend is asking about his 68 Gto how to do
Thx a lot !
Some pics ..
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 11-19-2019, 09:09 AM
gto4evr gto4evr is offline
I'm half way there right now. I see it's the same chevelle piece that I bought locally about two years ago. I've gotten as far as cutting out the upper panel but got stalled there. lots of fab work ahead of me. I already cut the spot welds taking those chevy end brackets off, but I see in your pic you're in the same boat I'm in. the rot on the top of the original goes back deeper than the new piece will cover so you'll be adding material to the top to stretch this panel deep enough to get to good metal on what's left of the top. I don't think it hurts anything but the chevy piece also rolls down on the front edge that should be trimmed off since it should be flush with the top of the original pontiac version as an extension of the top. I don't think it would interfere with anything by leaving the lip there other than looking wrong from underneath.. What stalled me is lack of time along with the fact I've got rot going down into the cowl dip as well so I've got nothing to weld the patch to along the bottom. Material needs to be added there as well to build up what's left of the lower cowl. Very frustrating having to literally build 4 pieces of metal back into a single piece and then hope it actually contours correctly to accept the windshield close enough to actually seal up correctly. Anyways, between lack of time and how complicated the repair will be, I'm not done and the car's buried under junk again. I'm planning on getting everything opened back up to work on it by the end of the week so I can snap some pics of my progress so far. At the rate I'm going, maybe some miracle will happen and someone will offer an actually useful a repair panel that actually works on a pontiac without all the fabrication by the time I actually get moving on this again!
Old 11-19-2019, 09:28 AM
Half-Inch Stud's Avatar
AsYou know, the Air nibbler may be your best friend. Metal guide will help make a straight-cut.
Old 11-19-2019, 10:48 AM
All words spoken ..same my friend says ..that’s a lot of work .. the panel should be a great help but it’s still a one million dollar job ...
please keep us updated!!! Pics always welcome
Old 11-20-2019, 05:58 AM
This is the chevelle piece grafted in. Have your windshield handy for fitting and take your time. We trimmed the new piece first, then used it to mark where to cut the old.
Old 11-20-2019, 10:36 AM
dataway's Avatar
dataway dataway is offline
Nice work!
Old 11-20-2019, 10:30 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
I'd look for a new dash panel. The rust that is forward of front speaker grill for defrost vents is too far gone for this patch panel unless you totally block/remove them. jmo
http://forums.maxperformanceinc.com/...d.php?t=661686
Leo
Old 11-21-2019, 09:48 PM
...Epoxy-in the new panel vs a total weld deal.
Old 11-22-2019, 02:53 PM
That’s was his first tuning ,) .
Cutting the rust area from dash top and finally cutting the new panel in place .. lots of fitment .. lots of pre work ..
ID:	525133   Click image for larger version
ID:	525134   Click image for larger version
Old 11-22-2019, 03:02 PM
Exactly how we did it.
I want to re-skim mine with bondo and make it perfect. I didn't realize that can be seen behind the windshield. Keep that in mind.
