Old 11-19-2019, 09:03 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Default Intake castings numbers
Were can I find all of the casting numbers for 68 intake manifolds?
I bought a set of 96's and trying to figure out what intake is correct.
Thanks!!
Old 11-19-2019, 09:29 PM
johnta1 johnta1 is online now
Intake Casting Codes
Type 1968 into the Year input box.
Old 11-19-2019, 10:50 PM
gtokid1968's Avatar
Thanks!!
Old 11-23-2019, 12:24 PM
Would probably want nothing earlier than a D date code if going for realism.
Best wishes on your build. Keep us in the loop
Old 11-23-2019, 05:46 PM
Kenth's Avatar
Kenth Kenth is offline
IIRC the #9794234 intake came with the Ram Air II engine in mid-May 1968.
Before this the #9790140 intake was used.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-23-2019, 09:59 PM
Believe they started casting the parts in March (C) and April (D)
Somewhere on here before i think there was a witch hunt to try to determine the breaking point on the intakes (date-wise) , but i have forgotten the results now.
Once it was switched to 234 - everything went to 234 across the board.
approx Mid-May was when car assembly/production started
Old 11-23-2019, 10:04 PM
Quite a few high mile "140" & "234" 4bbl intakes cracked up through the secondary divider. Have examined examples that the crack was so bad up from the heat crossover that an 8 penny nail would fit down in the crack...instant EGR! Buyer beware when dealing with sellers who don't clean their parts up.
Old 11-25-2019, 11:46 PM
68pongto's Avatar
68pongto 68pongto is offline
I have a C088 9790140 and a C198 9794234, so the intake part number change-over was mid-March 1968.
The Following 3 Users Say Thank You to 68pongto For This Useful Post:
Old 11-26-2019, 09:27 AM
Half-Inch Stud's Avatar
Same manifold design for 350-428HO & 455 HO & RAI, IIs, IIIs.
Has anybody seen a Plenum or Runner difference in 4234s, 0140s, and the 1970 manifold ( because I havn't).
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 12-02-2019, 09:20 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
I have seen no differences between the early/late 68 intakes (same part number 4234 for 69 also, date dependent). I think I have approximately (30) 68 intakes. I have not found a cracked plenum in any of mine, but I have yet to clean ALL of them yet.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 01-31-2021, 12:36 AM
Bird_collector's Avatar
Bird_collector Bird_collector is offline
Accidentally replied.
Old 01-31-2021, 04:37 PM
68gtoMN's Avatar
If I remember correctly, BOSS was looking for D248 as the date for the RAII engine's intake.
'70 LeMans Sport
Facebook Event
