Old 11-22-2019, 07:17 PM
2015XDRIVE 2015XDRIVE is offline
Default 66 gto clutch return spring
Haven't been able to get an answer on where does the return spring attach at opposite end from Z-bar? A photo would be great or a diagram if someone has one.
Thanks!
Old 11-22-2019, 09:03 PM
Jeff Hamlin's Avatar
Search CLUTCH RETURN SPRING within this Tech section.
Cheers.
Old 11-22-2019, 10:33 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
One end attaches to the clutch arm, the other end should attach to the z bar just above where the clutch rod. There should be a small hole there for the spring. All it does is keep the slop out of the linkage.
Old 11-22-2019, 11:00 PM
Thanks Jeff. I had searched this before but did not understand what the photos were taken of. I will crawl under the car tomorrow and look at body mount for hole.
BTW thanks again for the emergency brake bracket. everything works great!
Old 11-22-2019, 11:01 PM
Thanks for the info!
