Old 12-07-2019, 10:05 AM
gtohunter's Avatar
gtohunter gtohunter is offline
Had I known all you guys were electronics "gurus", I'd have picked your brains a little! I did some work on my Hammond organ, recapped amps, new tubes, cleaned contacts, etc., and when all that work was done, had a 60hz hum I couldn't find the cause of. After a month of poking, checking my work, etc., found 1 strand of wire on a soldered connection, on the tube heater circuit, going to ground when putting the cover on the terminals! I'd have the cover off, everything checks out with regard to voltages. Put the cover on thinking I'm finished, problem resurfaces!
My old eye's didn't see that strand of wire until I took a very bright light and that's when I saw it! All's well now!
Jimmy M
68 GTO
Old 12-07-2019, 12:31 PM
bird72's Avatar
bird72 bird72 is offline
I dig the old Hammond set ups. ABB freak so B3 heaven.
72 Bird
Old 12-07-2019, 01:16 PM
gtohunter's Avatar
Had several..B3, C3, D model, A100, and now this A102/leslie 122. What surprises me is that the guts of these A series are simply a B3 with internal speakers and a different cabinet, but they're dirt cheap compared to a B3!
This one is staying for awhile!
Jimmy M
68 GTO
Old 12-07-2019, 04:49 PM
Half-Inch Stud's Avatar
Had a Hammond M1 & an M3
Old 12-07-2019, 05:16 PM
dataway's Avatar
dataway dataway is offline
Where is the Leslie ?
Old 12-07-2019, 05:55 PM
gtohunter's Avatar
Sitting right beside the organ...It's a 122A
Jimmy M
68 GTO
Old 12-07-2019, 05:57 PM
gtohunter's Avatar
They are still being used, chopped, resurrected...They are very much like the old cars; only so many around, and many are stripped for parts to keep others going. You can buy something new or newer to emulate the tone wheel organs, but it's just not the same sound.
Jimmy M
68 GTO
The Following User Says Thank You to gtohunter For This Useful Post:
Old 12-07-2019, 09:51 PM
I left an M3 in the BSMT of the JST PA home we sold. M3 was minty in & out. No space for it at our destination so maybe the Buyers kept it.
I colud stop by and ask.
Old 12-08-2019, 06:05 AM
dataway's Avatar
Actually I've never seen a Leslie in all it's original glory .. by the late 60s, early 70's most of them where stripped of their wood work and sitting on top of an amp.
I was fascinated by them when I was a kid.
Old 12-08-2019, 10:07 AM
Had a small Leslie: spinning foam reflector above (low, mid, wide?) range soeaker, and gave it away. I thought it sounded rather aweful with music or Bass going through it.
Probably best & only use is with the Hammond Tone-Generator signals. Or Robert Plant like vocals.
Old 12-08-2019, 10:55 AM
gtohunter's Avatar
Had a small Leslie:
A big hammond through a "non leslie" speaker doesn't have anywhere near the punch that one through a leslie has, especially the highs. The high freq. driver sends everything >800hz through it, and that's where the good stuff happens!
Jimmy M
68 GTO
Old 12-08-2019, 11:50 AM
Lee's Avatar
Lee Lee is offline
I'm not sure how many people know this, but forum member "Stick Boy" (Obeid Khan) makes his living building/designing amplifiers. The radio/dash in his '65 GTO inspired the faceplate of his PAK series of amps.
https://khanaudio.com/pak-amp/?olsPage=products
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 12-09-2019, 02:15 PM
stags's Avatar
stags stags is offline
HIS - I still have that unit - it does sound pretty lame and haven't played it in years but cant part with it, or maybe I just don't want to move all the stuff on top of it haha. Would like to hear it slowed down.
The Kahn amp looks interesting. Friend of mine is looking at a Quilter but I'm gonna show him the Kahn and maybe get myself one.
To the OP and other amp builders - I do all sorts of mods to my guitars but leave the amp tinkering to others. At 66, not sure I'll be playing long enough to worry about it but "hats off" to your skills.
Ain't as good as I once was, but I'm as good once as I ever was.
The Following User Says Thank You to stags For This Useful Post:
