If you're running enough valvespring pressure to warrant them, or looking for the most durable possible part then you shouldn't be afraid to spend the money. Buying cheap stainless rockers that *might* not last just seems like false economy. If we knew these were a quality part and the equal of the Crowers then that would change the equation, but as another poster said above, I don't want to be the test dummy. And, I know the HS rockers are good enough up to the point where you actually need a stainless rocker.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
What am I missing? I thought your motor was done, dyno'd and in storage.
Triple Black 1971 GTO |
Again I am not changing anything I am just curious if this stainless rocker was as good as the crower. I have a 66 Tempest that will need an engine eventually when it comes up on the restoration list
I used a set and echo Cliffs comments, but my experience was in 2015. They were junk. After less than 500 miles and several dyno pulls three of the rollers didn’t roll and several more were very high friction. I replaced them with Crower Enduro’s and they have been flawless and much quieter.
You ask for opinions and then argue when you don’t get the answer you want. Caveat Emptor. |
I bought a set of the PRW years ago for a street project and ended up trading them off. I currently have 3 sets of the Crower Endurance on my rides.
Has anyone seen the ELGIN Stainless? Are these the same as the PRW?
The Elgin stainless are my next purchase to replace my 34 year old Comp Magnums. I wouldn't be surprised if the PRW are made by Elgin.
The only three types I'll even think about using here are Crane Gold Race, Harland Sharp, or Crower Enduro's. We've have had issues or known others to have issues with just about everything else out there.
A good factory stamped steel rocker will get the job done nicely for most of these builds (we are in the Street section). They are light, strong and you really aren't giving up anything as far as power is concerned. I just don't like using them with really high lift roller camshafts as that's just really not what they were meant for......
I wouldn't buy the PRW junk again, I tried a set of stud girdles, but the tall polylock nuts were machined so far off concentric that I couldn't get the girdle bars over them. The Pontiac vendor sent me another set of polylocks but these were the same.
