#41
I don't think I've ever seen that coded on any Pontiac before, so pretty cool. |
#42
pontiacmonstr, this should serve as a good example of the difficulty of recreating an accurate repro Data Plate if you don't do a LOT of homework. |
#43
I'm not sure insulation/dum dum delete was coded on the cowl tag (although it seems like it should be). I know Tenney's '64 is an insulation delete so I'll check the tag the next time I see it (I don't believe I have any photos on hand). K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
#44
One possible explanation for having a 5 Group code for the Heater Delete and NOT coding the Insulation Delete, the Heater Delete was a Regular Order option for '64 & '65.
Sales code 584 both years. Insulation delete was ordered as a Special Order item, it had to be requested by written instruction and then approved. There was no Sales Code for it. I suspect that Memo 198 was the PMD Sales Dept. approval specifically to address the Insulation delete for the Wangers GTO. Memos were issued for all such Special Order items, including my favorite, the '64 GTO built with the standard Tempest hood. Very likely, no 5 Group codes were generated for Special Order items. |
#45
The body sequence does seem way out on the 05C car, along with other things you guys pointed out. Is there any chance that any of your other specimens are 05B, 05C or 05D Hardtops ? Just to eliminate all possibilities.
#46
Do you know what year chevy color ? I really like that car and have the Die-Cast Replica of it. Quote:
Figured it must have had something involved with race build heritage. Will have to check the die-cast replica and see if they nailed that delete. Its a very high effort detail replica build on the car. |
#47
I do not.
#48
I (thought i knew) the lower right corner number on these was supposed to be the body jig.
But didn't know what the gate term was all about. Didn't want folks , or myself , to start thinking that was the gate where it entered or left a certain building. lol This is from my 65 07A - Pontiac Plant (7/14/5 BHC / invoiced) Black - Black Bucket interior WS - 4spd WideRatio - 3.90 No pwr steer, no pwr brakes Redlines , dog dishes AM P-button Dual speed wipers Splitters Back-up lamps Tach & Gauges Wood wheel Softray - All Console Deluxe front belts HD Fan Metallic shoes |
#49
I bet you changed that cowl tag to have the famous AA paint code. Just kidding
#50
hahaha
we didn't have those alternatives back in 90 or 91 .. i don't think we did anyway. Got lucky as heck when found this one. http://forums.maxperformanceinc.com/...1&d=1400210973 |
#51
Next time I run into Rick I'll see if he still remembers. The 1st issue/release from SUNSTAR was the closest, detail is so-so. You know I too don't recall if it had the dash detail. The 2nd 1/18th and other scales that followed are not as good, the last few releases even Dropped Ricks name SORRY BACK TO TOPIC...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 03-08-2015 at 08:26 AM. |
#52
Ibm card
#53
Card
#54
Ibm
#55
Ibmcard
#56
We do sometimes track vehicles as they pass certain "pay points", especially now that the builds are broadcast on electronic billboards throughout out the plant. K
#57
Pontiacmonstr , here is the basic stuff
65 GTO Hardtop Dk Blue E-E / Black Bucket Interior 213-B VIN 237375P149084 12-11-64 Invoice Date 08-283 - Paradise Pontiac - 8004 Lorain Ave - Cleveland OH 44102 382 - GTO 392 - AM Pushbutton Radio with Manual Fender Antenna 421 - Washer & 2spd Wipers 534 - HD Engine Fan with Clutch (20 inch with notched blades) {required w/ 3.90} 601 - Console 692 - Metallic Brakes 703 = 701 - Safe-T-Track (posi) 702 - Special Order Perf Axle Ratio 71P - 3.90 Axle Ratio 72C / 73C - Redline Tires (standard) 744 - V8 Synchromesh 4spd 75W / 76S - WS TriPower Manual Engine 779 - 4spd Wide Ratio Trans (M20) (Dog Dish hubcaps) (Single Pinstripe - probably White) (Black plastic covered seatbelt buckles - front only - non retractable - bolted to floor) (NO driver side rear view mirror) (Standard interior rear view mirror - non flip) (NO back-up lights in rear bumper) (Steel tailpipes - likely turned down under rear bumper ?) (4 core radiator with finger guard) {standard w/ 3x2} 2LG 5N |
#58
Thought it was great quality and detail for a die cast of the price. (about $20) Moved in 2009 and all that type stuff is still packed and stacked in boxes. If you can get to yours - check the dash for block offs - and underhood (no heater box). Will be cool if they got that right ! |
#59
Wow! Pretty good options to go fast (racing)!
QUOTE=Baron Von Zeppelin;5197762]Pontiacmonstr , here is the basic stuff 65 GTO Hardtop Dk Blue E-E / Black Bucket Interior 213-B VIN 237375P149084 12-11-64 Invoice Date 08-283 - Paradise Pontiac - 8004 Lorain Ave - Cleveland OH 44102 382 - GTO 392 - AM Pushbutton Radio with Manual Fender Antenna 421 - Washer & 2spd Wipers 534 - HD Engine Fan with Clutch (20 inch with notched blades) {required w/ 3.90} 601 - Console 692 - Metallic Brakes 703 = 701 - Safe-T-Track (posi) 702 - Special Order Perf Axle Ratio 71P - 3.90 Axle Ratio 72C / 73C - Redline Tires (standard) 744 - V8 Synchromesh 4spd 75W / 76S - WS TriPower Manual Engine 779 - 4spd Wide Ratio Trans (M20) (Dog Dish hubcaps) (Single Pinstripe - probably White) (Black plastic covered seatbelt buckles - front only - non retractable - bolted to floor) (NO driver side rear view mirror) (Standard interior rear view mirror - non flip) (NO back-up lights in rear bumper) (Steel tailpipes - likely turned down under rear bumper ?) (4 core radiator with finger guard) {standard w/ 3x2} 2LG 5N[/QUOTE] |
#60
Do you guys think this car was a special order or run of the mill car back in the muscle car days?
