Old 07-31-2007, 09:38 AM
Displayman's Avatar
Displayman Displayman is offline
Location: Hampshire, Illinois(50 miles west of Chicago)
Default Adding 65 stainless splitter tips
Does anybody have any info on the exact location
to mount splitter tips.
I just purchased a pair for my 65 GTO convertible,
and I want my shop to install them in the correct location.
I have viewed several of the pics on this site but I am
looking for some specs or info.
Thanks for your input
Bob aka(Displayman)
65 GTO Convertible
67 GTO Sport Coupe
38 Chevy Pickup Hot rod
Old 08-01-2007, 06:40 AM
jjscerbo's Avatar
jjscerbo jjscerbo is offline
Here is an instruction sheet from the repro splitters. Bad picture but may help.
With all of the modern advances in technology and medicine, there is still no cure for the common birthday - John Glenn
Old 08-02-2007, 10:27 AM
Displayman's Avatar
Default Adding stainless splitter tips
Thanks for the info,
but I am unable to read the instructions
that you had sent.Too small on computer.
Thanks anyway.
Bob ( Displayman)
Old 08-02-2007, 03:31 PM
65Tiger's Avatar
65Tiger 65Tiger is offline
I just installed the factory splitters and used the reproduction splitter brackets. They are about $50 but mount the splitters in the correct location and include the instruction sheet posted above.
Old 08-02-2007, 11:51 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Accessory Tailpipe splitters
Instructions for splitters:
Peter Serio
Owner, Precision Pontiac
Old 08-03-2007, 11:41 AM
Displayman's Avatar
Default 65 stainless Splitter Tips
Pete,
Thank you!
I was able to read
the file showing the
installation.
I can't wait to get them installed.
Bob (Displayman)
Old 08-04-2007, 09:48 AM
Displayman's Avatar
Default Adding 65 Stainless splitter tips
Installed the tips yesterday!
Looks awesome, and sounds great!
Thanks again.
Bob ( Dispplayman)
1965 GTO Convertible
1967 Sport Coupe
1938 Chevy Pick up Hot Rod
Old 08-04-2007, 10:37 AM
Dick Boneske's Avatar
Has anyone tried cutting the tailpipes without removing them from the car?
A related question--My exhaust system is free of corrosion, but there has been leakage on both muffler to tailpipe seams from the day it was installed. Very small leak that "squeeks" when the engine is revved. If I remove the pipes, what kind of exhaust sealer have any of you had success with? I have already tried heavy duty muffler clamps, multiple clamps, air wrench torquing until the muffler clamps break, etc.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-05-2007, 10:05 AM
65Tiger's Avatar
I cut my exhaust while on the car to install my splitters. I bought a tool from an auto parts store that is like a large pipe cutter but with four cut wheels. It only takes a 1/3 of a turn to cut it off. It worked great and only took about 3 minutes each to cut off.
Old 08-05-2007, 06:14 PM
Ken Dowdy Ken Dowdy is offline
Displayman can you post some pics of your final installation. I want to do the same to my 65, but have never seen a clean installation and one that didn't seem to position the splitters to low.
Thanks,
Ken
Old 08-06-2007, 09:13 AM
Displayman's Avatar
Ken,
I will try to take some pics today.
We used a SAWASALL to cut about
a foot off of each tail pipe. Then we swedged
the remaining pipe. We tack welded the remaining
pipe. We then positioned the tips on the tack welded
pipe. Once we were happy with the positioning, we
tacked welded the tips; double checking the appearance from
the side and from behind, then we finished the welding around
the spot welds.
For show quality, I would have new pipe made from the mufflers back.
Much cleaner than 2 welds in a short area.
Hope this helps.
Good luck,
Bob ( Displayman)
Old 08-06-2007, 07:18 PM
Displayman's Avatar
Here are some pics of the splitter tips that I welded on to my
existing tail pipes while they were on the car.
The car is a 1965 GTO unrestored convertible.
I hope these pics show up for those who are interested.
Later,
Bob (Displayman)
1965 GTO Convertible(unrestored) rebuilt 389 3 deuces 4 speed
1967 GTO SPort Coupe project
1938 Checy Pick up Hot Rod
Old 08-06-2007, 10:44 PM
Thanks for the pics Bob...Looks like you did a great job of positioning them. That's the way they should look in my opinion. Good luck with your restoration.
Ken
Old 08-07-2007, 08:44 AM
Displayman's Avatar
Ken,
Thanks for the opinion on the splitters.
You really start second guessing the positioning,
before the final welds.
Thanks for everbody's info. It really helped me alot.
This is the BEST forum for GTO's!!!!!!!!!!!!!!!!!!!!!!!
Later,
Bob (Displayman)
1965 GTO convertible(unrestored)
1967 Sport Coupe -project
