Issues with 69 Firebird
First issue is the right turn signal indicator light, in dash, comes on when headlights are turned on. It blinks, as it should, when right turn signal is activated.
Second issue is the temp gauge goes to 250 degrees within a few miles even though my pyrometer tells me it is only at 180 degrees. Sending unit is new. Any ideas?? Thanks Steve
Steve 71 Pontiac GT-37 400 4 spd (sold) 71 Formula 400 turbo 400 (sold) 01 Firebird T/A WS6 auto (fun) 64 Tempest Post car LS1/4L60E (Love It!) 65 Lemans Post car LS1/4L60E (More Fun)(sold) 73 Lemans GT 400/auto 1 owner 52k miles 69 El Camino LS1/4L65E (Awesome) 70 Pontiac GTO Convertible 400/400 Original 69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569 |
sounds like a ground problem to me . make sure that the all the wiring harness connectors under the dash is plugged together good and tight. under the dash is a ground wire to metal mabee more than one wire. remove and clean each ground wire . if that doesnt help clean the ground wire from the firewall to the motor and the ground wire from the fender to the frame
connman |
It's likely that either the right front lamp socket isn't grounded properly or there is a problem with the bulb (this can happen if a single-filament bulb is installed in place of a dual-filament one). You could ground the bulb with a piece of wire as a test.
Lee Peterson ------------- "I didn't expect a kind of Spanish Inquisition...!" '69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car. |
