Old 06-25-2020, 10:49 PM
Bri70gto Bri70gto is offline
Looks great . I'm waiting for my pan from them also.
Sent from my SM-N975U1 using Tapatalk
Old 06-25-2020, 11:43 PM
Dragncar Dragncar is offline
Street pan or race pan ?
Old 06-26-2020, 10:47 AM
10 qt pan for my jet boat. Just talked to Stan it's going to ship Monday. Still waiting for my 535 short block so I'm putting my High port headed 490.
Old 06-26-2020, 02:50 PM
mgarblik mgarblik is offline
Would love to see some pictures of your jet boat and more info about the engine and drive. Start a new thread?
Old 06-26-2020, 03:38 PM
I'll do that.
Old 06-28-2020, 09:59 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Just curious.....what does a pan like this cost?
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 06-28-2020, 07:30 PM
cgeise's Avatar
cgeise cgeise is offline
FYI be carful using THE RIGHT STUFF -- if you use to much you will have to NUKE the pan to get it off , It is hell for strong and will bend a pan taking it off --
The Following User Says Thank You to cgeise For This Useful Post:
Old 06-29-2020, 03:39 AM
800$, pickup is another 50 or so. But I am making my own.
Old 06-29-2020, 03:51 AM
I won't use it. I have a tube of this International silicone, like 30$.
I used The Right Stuff on my 9" housing. I had to use a come along and a big dead blow hammer.
Never again.
Old 06-29-2020, 07:29 AM
charlie66's Avatar
I agree about the Right Stuff being over kill. But if you ever did run into the problem of getting a pan off or anything for that matter. A spackel knife and a hammer will cut through it like butter. It makes it a breeze believe it or not.. Just use the corner of the knife and go in on an angle..
My Half AN Injun.....
Old 06-29-2020, 07:58 PM
68azbird 68azbird is offline
that should be interesting
It is easier to fool a man than it is to convince he has been fooled
Old 06-29-2020, 09:32 PM
What is so interesting about a pickup ? Since it has a larger tube it will be better than any stock or Canton type or any other one that uses that small tube with tight bend.
Really not much too it.
Old 09-27-2021, 04:56 PM
Adding a scrapper to this pan.
Old 09-27-2021, 07:25 PM
wreckmastr's Avatar
Never again.
Permatex "Ultra grey" FTW
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 09-27-2021, 09:37 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Enlightening
Go fast, see Elvis!
Old 09-28-2021, 07:25 AM
slowbird's Avatar
slowbird slowbird is offline
Dragncar, how are things going on the build? The pan is for your stock block hp headed engine correct?
Old 09-28-2021, 05:15 PM
Yes, that engine. Pan will go on the IA2 if i ever get that done. I have a std Canton pan I can modify for the stock block engine if I need. The HOs will go back on it as I do not want to push a stock block to over 700 HP for very long. I will not run it at those power levels much anyway, just want to see how it does. Feel the power you know.
Shortblock is together, cam degree,d.
Stopped working on it after I went to graveyard shift and it made it hard to get anything done. Terrible shift.
Back on swing with a raise so I am working on it again. Car was not ready anyway, changes need to be made. (mid plate, V pump ect.) so the drag season was not going to happen.
Heads are ready to go, intake needs a little milled off as I took .030 off the 80cc High Ports.
Have a sweet custom 1050 built for the engine. New set of 2" Mad Dog headers. Putting a 02 bung in them.
I put the thread back up just to show someone else a pic of the pan. Steffs is sending me a bolt in crank scrapper for free. Bolts on 1 1/2" below the pan rail. Then I Johnson is making me a Teflon scrapper that is going on the pan rail.
Never head of anyone running 2 types of scrappers before but it looks like I am going to try it.
