Steering column question
I am rebuilding the column in my '71. Is the backdrive shaft pressed onto the shift bowl? I do not see any fasteners...
Don't remember that assembly detail but I found this useful when I rebuilt mine. Hopefully it has the answer. If not, I apologize in advance for being too lazy to look through it again:
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf |
look here..i think it has step by step..guy has a lot of useful info..not sure if it has what ya need or not
http://www.buickperformanceclub.com/page1.htm http://www.buickperformanceclub.com/...lumnwobble.htm
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
Unfortunately all those are for tilt columns - this is a non-tilt unit.
If it is a press-on deal, I will let that sleeping dog lie. |
You have a copy of a service manual? My 70 book has a diagram and a description of disassembly. I'm happy to scan the description if you think it would help. I bet you have it figured out, though, and the assembly is not intended to be separated but here's the diagram and key:
Last time I did a deep dive in a steering column I had the same question. I recall that it is a press-on deal and there's a special J-tool to get it off if need be. That could be tilt only though, my memory is fuzzy.
Thanks for the illustration - I have 2 manuals, '71 and '72 and did not see the non-tilt in either.
I will clean it as-is, I cannot see a good reason to risk damage by separating just to clean |
Thread Tools | |
Display Modes | |
