Old 06-26-2020, 03:46 AM
fbd73's Avatar
fbd73 fbd73 is offline
Default Lower valance not aligning
Hi All,
we are trying to put the car back together for its repaint and the lower panel under the nose cone won't go back flush. The gaps above the indicators is a lot wider than they were before the panel was taken off and there is no way the centre will go close enough to bolt up to anything. The section under the indicators seems to line up with the front part of the fenders.
Any ideas???
Name:	Centre of lower nose cone.jpg
ID:	543340   Click image for larger version
Name:	Gap on LH lower nose cone.jpg
ID:	543341   Click image for larger version
Old 06-26-2020, 02:58 PM
Transamric's Avatar
How is the fit from the bottom of the valance panel to the lower radiator support? Is it too low to match up also?
Old 06-26-2020, 03:12 PM
Formulabruce's Avatar
let's see pics of both sides to fender. The J bracket behind bumper should be installed for mock up and the lower valence brace which attaches to it.
Old 06-26-2020, 04:20 PM
necdb3's Avatar
necdb3 necdb3 is offline
Originally Posted by fbd73 View Post
Hi All,
Any ideas???
Is it a 73? If so, I would get a plastic one for it. They look better.
Old 06-27-2020, 03:42 AM
fbd73's Avatar
Here are close up pics and one of it before we took it to the paintshop.
ID:	543503   Click image for larger version
ID:	543504   Click image for larger version
ID:	543505   Click image for larger version
Old 06-27-2020, 03:47 AM
fbd73's Avatar
More pics. Before the paint job started and one as it is at the moment.
Name:	Lower nose cone.jpg
ID:	543508   Click image for larger version
Old 06-28-2020, 03:28 AM
I think that the lower valence is a repop based on the side pic.
It fits like a steel repop in that area.
Old 06-28-2020, 05:41 AM
fbd73's Avatar
Would that make a difference? Whatever it is, it fitted before and it won't now.
It certainly has us stumped.
Old 06-28-2020, 10:08 AM
FrankieT/A's Avatar
Looks like you skim coated the fenders...Did you skin coat to adjust gaps?
Old 06-28-2020, 11:33 AM
From my experience, I have found that the repop valence, if you make the front line up, push it up, the bottom side to fender has a gap. Yours would look like that if it was loose and you brought up front.
Do you have 2-3 washers spacing the core down off the bottom of the subframe?
Old 06-28-2020, 09:54 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Looks like the fender flange was built up with filler. The fender should angle back just below the nose. Yours is tilting the valance forward maybe 1/4". The centre of valance looks flat and needs to be bent back.
