Old 07-05-2020, 10:05 PM
DM3 DM3 is offline
Default Installing heater box question...
I am gonna attempt to remove the inner fender well and then install the heater box.
My question: is there any kind of sealant that needs to be install between the heater box and the firewall?
If so, what kind can be used?
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 07-06-2020, 08:29 AM
mysticmissle's Avatar
i think it is like that butyl tape. a type of weather stripping. may be able to find it local at a lumber yard
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-06-2020, 09:51 AM
1972 Goat herder's Avatar
1972 Goat herder 1972 Goat herder is offline
I have reinstalled a couple in the past and used a 3M product. It is called 3M Strip Caulk. Product number 08578. It is widely available and works well.
Old 07-06-2020, 10:24 AM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
are you replacing your heater core? I was able to change mine without removing the inner fender. I used long extensions to go over the fender well to get to the last nut. It wasn't fun but not impossible.
67 Firebird Convertible
Old 07-06-2020, 10:14 PM
DM3 DM3 is offline
Thanks, I had to order it, not in stock. I assume it has to go on both side of the fire wall.
1967 Firebird 400
Old 07-06-2020, 10:16 PM
DM3 DM3 is offline
Replacing the whole heater, blower, covers, etc... I have tried to install the blower fan and cover and can not get it in there, the fender is in the way.
1967 Firebird 400
Old 08-14-2021, 06:31 AM
grivera's Avatar
grivera grivera is offline
were you able to remove just the inner fender - leaving outer fender in place? If so - how did you do it? I have to do Vintage Air soon and have been dreading this part of the project.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 08-14-2021, 03:41 PM
68 BlueBird's Avatar
68 BlueBird 68 BlueBird is offline
I recently went through this. It's not possible. At a minimum, you'll need to pull the fender away to make room for the inner fender to come out and when you do get the inner fender out, the fender will still be in your way. It's easiest and fastest to pull the fender and inner fender as one piece. You don't even need to take the tire off. I definitely recommend 2 people for this, to prevent bumping panels and chipping paint. The good news is that it's not as difficult as you think it will be. If you can get all the bolts broke loose without snapping any off, you'll be done faster than you think.
1968 Firebird - IAII 535 - FAST Sportsman - 4L80e - PTC 10" triple disc 3800 stall - Moser 12 bolt 3.55 - Caltracs - Hydraboost
Old 08-15-2021, 08:14 AM
DM3 DM3 is offline
As said below, both have to come off, so I still have not done it yet.
1967 Firebird 400
Old 08-15-2021, 01:27 PM
Sport69 Sport69 is offline
I've seen inner fenders with trap doors cut in them that you can open and shut as needed. Before I restored my 69 it had a trap door on the inner fender.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 08-15-2021, 02:14 PM
gobrdgo gobrdgo is offline
Plus one on the butyl stuff. Works great and if you have to adjust or remove again it doesn’t dry. Easy to work with.
Old 08-16-2021, 05:12 PM
StevenK StevenK is offline
I made a ratchet system with a snap-on 1/4 ratchet, with pipe extension on the handle and then a wheel pully to turn and reach that upper fender wall nut. Worked like a charm. Trying to remember where I put it for a pic.
