Does anyone know if factory replacement or mild HP cams are available for the 4 cylinder. I checked with Melling, no luck.
I believe that Crane has cams available. Dave
I had the stock cam reground for my street car .350 lobe lift 220 @ .050
Please post what you find out from crane. thanks!!! |
No luck with Crane, they said if they could sill get the cores they used it wouldn't be that expensive. If not they would been to cut a roller cam @ $800.00.
www.egge.com They can regrind your old cam for under $100.00
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
What did you decide/find out? I'm needing 2 custom grinds .500+ lift/235 duration @ .050" each.
I'm working on getting pricing to have 5 to 10 cams ground. I'm looking to have the cams ground in the area of .450 lift. I will post the information as soon as I get it.
Definitely post as I may be looking for one in the near future too.
![]() Quote:
![]() Quote:
The cams I'm working on will be upgrades based on the 4bbl cam. My goal is to provide a cam that will perform similar to the stock cam and also provide a cam that will be a bit more aggressive, but will NOT be a full race cam. The main issue we are facing is the availabilty of usable cores. If anyone has an original NOS cam or a mildly used cam, I would appreciate your help. My cam manufacture would like to analize the cam BEFORE making the final commitment on specs. Once I get the details worked out, I would like to know the number of people interested in purchasing cams to achieve the best possible price. If anyone has a special request on cam specs, I may be able to grind a few cams as desired, but again the cores are limited. Feel free to contact me to discuss this further.
I would take one.
fasteddy |
Ray Bisig has some original flat tappet race cams you could borrow. I used a Isky 550 flat tappet in my first race 4cyl back in the 70's
I would give Nunzi a call,just for snicks and grins and see what he has.Tom
So what is the status on cams for the 4cyl?
![]() Quote:
Thanks. Hill Performance 708-250-7420 |
Isky Cams make several for the Iron Duke they have 14 of them in the catalog. MT used their cams in his engines.
http://iskycams.com/makesearch.php?c...7&engine_id=74
Never poke a bear with a stick! |
Sorry, wrong 4 banger, the 4cly we are talking about is the 61-63 195ci slant 4.
Jay |
About what dollar figure are we talking about here for each, if you get a 10 minumum order????? I will take at least 1, maybe 2 or 3!!!
Keith |
