Old 05-10-2024, 11:55 AM
drain89 drain89 is offline
Default WTB ‘63 bolt on AC crank pulley and “8AC” PS pulley
PS pulley is cast with 8AC cast onto the spokes
Crank is stamped steel or aluminum. Pic of crank pulley:
Old 05-10-2024, 06:24 PM
694.1 694.1 is offline
Not sure if this is aftermarket but bolts to the stock pulley.
Would this work?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 05-10-2024, 09:23 PM
Wat are the dimensions of it?
Old 05-10-2024, 11:28 PM
T.Weber's Avatar
T.Weber T.Weber is offline
The deminsions of my pulley where it would sit attached to the haronic balancer are 1 9/16" to the inside grove where the belt would ride - 2 1/4" to the out side of where the belt would ride inside that grove - if that makes any since and the OD of the pulley is 6 1/16". If you wnat pics with a tape against th epulley let me know.
Old 05-10-2024, 11:36 PM
T.Weber's Avatar
This is the bracket you need for the alternator to use a 61 - 63 A/C compressor mount:
https://www.ebay.com/itm/266355695031
As I stated earlier Franks Pontiac has the flat plate that bolts to this Alternator mount.
Old 05-11-2024, 05:12 AM
I have that bracket and the mounts. I also have the water pump pulley, 2 groove balancer pulley , and the power steering pump mounting bracket.
The only missing piece of the puzzle is the bolt on single groove pulley and correct PS pump pulley..
Old 05-11-2024, 11:58 AM
Would this work?
694.1 What is the dimensions of mounting surface to bottom edge of groove and top edge of groove? Bottom diameter at mounting surface and top diameter? Thanks
Old 05-13-2024, 09:13 PM
T.Weber's Avatar
Check out this guy Larry Groskopf, He's on face book and has the pulleys & Compressor with mounts for sale. He wants $90.00 for the pulleys & harmonic balancer
https://www.facebook.com/groups/2613...0002279058078/
Old 05-14-2024, 01:31 AM
Thanks pal, I sent him a message.
Old 05-16-2024, 11:14 AM
omarsphatt omarsphatt is offline
If you end up with any spare A/C pulleys you want to sell, let me know - I'm looking for the same. Do any of the ones you have, have part numbers on them?
Old 05-16-2024, 03:18 PM
I certainly will. These things are like trying to find hens teeth.
