Old 05-11-2022, 05:25 PM
61-63's Avatar
61-63 61-63 is offline
Default android borescope
Can anyone recommend a good android borescope? There a number of them on Amazon for $50 or less and I only want to buy one and be done with it if possible. I need one with a pretty small camera end because I will use it to look down into carburetor booster bores etc when centering drill bits and stuff like that, and rifle bores too.
Old 05-11-2022, 07:14 PM
mr67gp mr67gp is offline
Last year I bought and have been using a Depstech borescope with my Samsung S10. For the money it does exactly what I need, and operation is easy. uses WiFi to connect to the phone. Just used it to suss out a leaking freeze plug on my '57 Chieftain.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
The Following User Says Thank You to mr67gp For This Useful Post:
Old 05-11-2022, 08:46 PM
Murf Murf is offline
I have the Desptech also. I’m not sure the one I have would be small enough for you, though. I don’t have it handy but I’d guess the camera to be at least 1/4” diameter. Other than that it works fine. Maybe they have different models.
Murf
Old 05-11-2022, 11:03 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I also have a Despetch. It will fit into spark plug holes easily but I don't think it is small enough for what you need.
Old 05-12-2022, 09:25 AM
61-63's Avatar
Thanks guys
Old 05-12-2022, 04:53 PM
fyrffytr1's Avatar
Here are a couple pictures of the camera end on mine.
ID:	590660   Click image for larger version
The Following User Says Thank You to fyrffytr1 For This Useful Post:
Old 05-12-2022, 09:08 PM
61-63's Avatar
Thank you. I need to get one that would be able to fit in a .223 rifle bore. They make them and for not much $$.
