Old 03-11-2012, 12:34 PM
Pepi's Avatar
Pepi Pepi is offline
Default #5 Duct bracket
Does anyone have or know where to get the bracket along with the correct clip that secures the #5 duct to the #4/#6 ducts? I believe about 20 years ago when the heater core was getting worked on, the bracket got removed and never put back on.
I am having trouble uploading a picture, I'll keep trying.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 03-11-2012, 12:52 PM
Pepi's Avatar
Default Picture of bracket
It is somewhat hard to see, still having issues uploading a good picture. But in this one it is towards the top left of picture when not rotated.
Name:	duct bracket.jpg
Old 03-11-2012, 10:34 PM
70RAlll 70RAlll is offline
Brackets like this can be fabricated at home easily. Use standard sheet metal, like 3/16" or so thickness, get a pair of sheet metal shears and this bracket is only 1/2" or so and 4-5" long when laid out flat. Cut a flat piece, then use a drill to drill the holes on each end and I always use a vise to make the bends, but a sturdy set of pliers will work just as well. Then spray with semi black paint to retard rust and you will be fine. There are so many brackets like this that are easily made..
I think we are talking about the same bracket, the one on the top of the page??
Old 03-11-2012, 10:39 PM
The bracket I described in my previous post is labeled #9 in your schematic. I believe that is the only bracket used in the duct work on a 70-73F body..
Old 03-12-2012, 08:46 PM
Pepi's Avatar
Yes, #9 is the one I am looking for. I didn't know the width of the bracket, so that is what I'll do. 3/16"seems awfully thick though.
Old 03-12-2012, 09:31 PM
Formulabruce's Avatar
its more like 1/8 , roughly 16 ga steel sheet metal
Old 03-12-2012, 10:14 PM
yes..3/16" is probably too thick.. but is thinner than 1/8"...18 guage or so is most likely your size.. Someone with more time than I can measure for you..anyway, it is an easy bracket to fabricate, plus it is mounted in a position where no one will see it.. If i have time tomorrow I will measure one I have..
Old 03-12-2012, 10:15 PM
scratch the tinner comment, it is thicker..my bad
Old 03-13-2012, 05:50 AM
Pepi's Avatar
Cool, thanks.
Old 03-13-2012, 07:38 PM
Cool, thanks.
OK.. Here are pictures of the bracket you are looking for. Below are the spec's
width .75"
thickness .035" 3/64" inch
overall length 4.30"
length to 90 degree bend .80"
length to 45 degree curve from 90 degree bend 2.50"
Hole in 90 degree bend 1/4" round
hole in 45 degree bend two 1/4" holes opened up touching eachother to make an oval for adjustability..
Hope this helps you.. Should be easy fabricating this bracket..
Name:	AC bracket.jpg
ID:	278219   Click image for larger version
Name:	AC bracket (1).jpg
ID:	278220   Click image for larger version
Name:	AC bracket (2).jpg
ID:	278221   Click image for larger version
Name:	AC bracket (3).jpg
ID:	278223   Click image for larger version
Name:	AC bracket (4).jpg
Old 03-13-2012, 07:48 PM
Pepi's Avatar
Thanks 70RAIII, now I have my one more chore for this weekend
