manual steering box
manual steering box, fits many cars numbers are 5679142 and 5666723 this came off a restored car that was switched over to power steering nice 85.00
box
pictures
watching this
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
steering box
This needs a new home...........80.00
What is the condition of the box? Was there a lot of play in the steering wheel? What car was the box mounted in before removed and replaced with power steering? Why only 2 bolts where is the 3rd? Is the 3rd mounting hole OK, hard to tell in the picture?
Thanks, Mark
steering box
steering box is in great shape, no problems. It was taken out of a restored 64 GTO and converted to power steering. It fits many Pontiac's from 64 to the early 70's. I'll try and check for a date code and post it.
Sent you a pm
steering box
More info: code is A3258 or 3 last digit hard to read and 284 also stamped no play at all. third hole the threads are good but lost the third bolt
steering box
SOLD, THANKS
Sorry I missed out on this, personal things came up and it got away from me. I will keep looking for another one.
Thanks for the info, Mark
