235/60 r 15 tires on '66-'67 Tempest
Any of you use 235/60r15 sized tires on the front of your '66-'67 model? I presently have 225/70r15 BFG Radial T/As on the front of mine, and 225/70r15 on the rear. I want to go up a size on the front, and down a size on the rear so I can have the same sized tires, (a better overall look, and I will be able to rotate them.) Was curious about the wheel clearance and how this sized looks on these cars.
235/60s will work on the front. From Summit Racing: 235/60s.... http://www.summitracing.com/parts/BFG-09082/ 225/70s.... http://www.summitracing.com/parts/BFG-58541/ Look at the diameter and tread width for both. You'll see what I mean.
I've run both 235/60R14 and 235/60R15 for years on my 67 GTO. They both fit just fine up front. Two things though:
1. If you have a larger aftermarket front sway bar, you might rub on it just a little during full lock turns (only enough to touch, but no damage). 2. Also, if your factory springs have sagged a bit (or if you have lowering springs on the car), you might also rub against the fender a bit during cornering if you have a lot of weight in the car (like 2 or more people in the car). Not a big problem though, just something to think about. Enjoy!
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
At least I didn't read it wrong. I kinda thought you meant different but wasn't sure. LOL
I've got a 1-1/4" front swaybar and it clears the 70s I have with no problem. One that size should clear 60 series tires on 15" rims as well. The front end configuration of the 67 A-bodies and my 79 Formula look about the same, with the same amount of room in the front wheel wells and layout of the steering components. So I don't think there'd be much of a problem. When I finally get new tires for mine I'm looking to go 255/60-15s in the back and 235/60-15s up front. But first I have to spring for a set of 15x7 or 8" Cragar SSes for the front.
I have 235/60/15 up front and 255/60/15 in the rear with a wider rear 12 bolt from a 71. I do not recall the offset on the 15 rally one wheels, though.
I don't think I could go any larger on either. The rears have just enough room for me to run a finger between it and the fender. But it has never rubbed. The fronts have caught my wheel well trim a couple of times on sharp turns that involve a dip or a bump in the road. There are a couple of pics of my tires in this thread. http://forums.maxperformanceinc.com/...12+bolt+finger I got all of my advanced info from PY member Champ, he knows his stuff on tires.
Mitch Kunath |
Ride and handling is fine but in all honesty I feel no discernible difference from when I was running 14" wheels. But I really like the way these fill out the wheel wells to the max.
Mitch Kunath |
I have 235-15 on the front and 245-15 on the rear. As Goatmanmitch said, hitting a bump while turning hard, like into a driveway, the front will rub, if I am going too fast, but never while driving at cruising speeds.
Those tires look good on there. Nice looking car. I'm looking for a little more rubber on the road like you have. Ride , handling, and roadholding are important to me, especially with the 455 and overdrive like I have. Gives a better safety margin (like when someone cuts you off) at the comfortable, higher cruising speeds I attain with this combination.
A better swaybar up from will help handling.... 1-1/4" works great. Maybe boxed lower control arms with a swaybar for the rear..... 1-1/4" too maybe. Better shocks too. Just bigger tires and tire tread alone won't improve things, and give you the handling you might want.
You've got the good stuff, now the tires should be the last good thing to finish it off. Once you get them on, we'll need some photos.
Have tires on there and they look good. They don't seem to rub anything. Having trouble with uploading pictures on computer right now. Will post as soon as I can get this problem solved. Thnks for the "pre advice" all you guys.
I do!
"Don't let fatigue make a coward of you." |
nice looking car Shawn.
Interesting, last year I switched to Rally IIs and 235/60r15s all the way around on my 66 and have no rubbing issues. I installed brand new coils and cut the front by 1 coil, no rubbing.
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust |
What width and backspacing are the RallyII wheels?
Thanx |
Finally was able to get at least one picture of my car with the 235/60r15 tires on the front up. Sorry it took so long. Computer had download problems. No rubbing problems. Nice ride too. Thanks for the input guys.
