Hi guys,I am in need of a electronic dist. that will fit on a 400ci with tri-pwr.It's for a 66 lemans. Thanks for any help locating one and where I can get one.(reasonably priced)
Tim |
just convert your stock 66 dizzy to electronic.Many of them out there.I run a Dave SB HEI and also pertronics in stock dizzys.FYI,you will need to have a 12V wire to the coil to replace the resistor wire.Tom
I believe a stock HEI will fit if a small amount of material is ground off the dist.
HEI has a better triggering mechanism. |
![]() Quote:
I first found Dave on the internet about 20 years ago, and thought he was full of crap about how good his conversions were. I bought one, just so I could see one in person, and report back what a phony he was. Turned out to be an excellent product! I've since used him on every project that I could. You send him your stock distributor. He rebuilds it, and performs his conversion. The wiring coming out will look a little different, and the HEI module is mounted externally (either remotely, or to the bottom of the housing), but few people will ever notice.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Thanks everyone for all your help,I don't have a stock dist. just the electronic one that came with my car when I got it.Geoff you said that you think that I can just remove some material ,where and will my cap be ok?
Does anyone know if Daves has complete distributors. Thanks guys, Tim. |
![]() Quote:
If you are polite and patient with Dave, and ask nicely, he MAY have a core that he will use for you. Sometimes he just does not have any though. If not, you may be able to find one on eBay and have it shipped direct to Dave.
Tim,
Not 100% sure about HEI fitting with T/power but do recall some people saying HEI will fit a little grinding. If you have a HEI or can borrow one, you can check? The bigger cap [ bigger gap between segments to reduce cross firing ] of the HEI & more accurate triggering of the HEI are both pluses that small cap dists do not have. |
Here's an update,I just spoke to Dave and he said that I have to get a good core for my rebuild.I need a dist core from a 326ci to 428ci engine.I'll see what happens,hopefully someone has one.Thanks again everyone for all your help.
Tim |
