Old 09-04-2021, 06:37 PM
jrunner jrunner is offline
Default WTB Ohc6 250 crankshaft gear. 1968 1969
Hi guys I’m looking for a 68- 69 ohc6 250 crankshaft gear. My old one has been machined for a new key groove. Please see pictures.
Thank you. Please message or call.
John 213-435-5151
ID:	572486   Click image for larger version
ID:	572487   Click image for larger version
ID:	572488   Click image for larger version
ID:	572489   Click image for larger version
Old 09-04-2021, 09:49 PM
694.1 694.1 is offline
Can't you just use the correct groove? Or maybe it is damaged. I should have one around.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 09-04-2021, 10:33 PM
Default Crankshaft gear
Hello no the original groove looks like the key moved side to side and gouged the hole in the gear and someone machined another groove in the gear. Please see picture. I’d rather use a gear with the factory groove so I know the timing and belt position is dead on. If you please can you check to see if you have another 250 gear ? you can sell me?? Thanks John
Old 09-04-2021, 11:28 PM
66sprint 66sprint is offline
John
I can get one to you. Just send me a private message with your address.
Chris
Old 09-05-2021, 03:14 PM
Jeff Hamlin's Avatar
Thumbs up
Also, have a 250 Crank Sprocket if something doesn't work out.
Old 09-05-2021, 03:27 PM
Thank you
Old 09-08-2021, 09:04 PM
I found a crank sprocket to send to John but it was in a box with a variety of spare parts.
My question is are there 2 different sprockets 230 and 250 or are the all the same?
If different how can I tell if this is a 250 crank sprocket?
Chris
Old 09-09-2021, 12:24 PM
I think I found the answer inner diameter on the 230 is 1.25” and the 250 is 1.3125” (1 1/4” v. 1 5/16”).
Sound right?
Old 09-09-2021, 01:21 PM
Thumbs up
Correct the 250 Crank snout is larger.
Name:	CRANK 250 SPROCKET.jpg
Old 09-23-2021, 12:58 AM
Default 250 Crankshaft Gear
Update: thank you 66sprint for sending me a crankshaft gear you too Jeff for helping out really appreciate the help would have never found a gear here in Los Angeles.
ID:	573602   Click image for larger version
The Following User Says Thank You to jrunner For This Useful Post:
Old 09-23-2021, 09:24 PM
Glad to help out. Let me know if you need anything else and keep us posted on the build.
