Old 03-16-2023, 10:17 PM
kpbrown31 kpbrown31 is offline
It seems everyone is calling the 17749’s a very quiet option. Is it like factory quiet, or does it have a little rumble? I’m wanting someone that is slightly above factory noise to at least let you know you have some motor.
  #42
Old 03-16-2023, 10:43 PM
If that’s what you’re looking for in a muffler they’re the right ones for you.
  #43
Old 03-17-2023, 12:50 AM
gokitty gokitty is offline
Just replaced my Flowmasters with a pair of Borlas . The sound is just right...inside and out
  #44
Old 03-17-2023, 11:19 AM
imposter's Avatar
imposter imposter is offline
what about a walker 18293
  #45
Old 03-17-2023, 10:00 PM
70GS455 70GS455 is offline
No, they are not factory quiet. Louder, but not obnoxious
Sent from my SM-S901U using Tapatalk
  #46
Old 03-18-2023, 12:34 AM
Pipe size makes a big difference - 17749's and their 2-1/4" equivalent are different in their noise level. 2-1/4" are almost factory quiet - the 2-1/2"s quite a bit louder but not obnoxious or ticket worthy.
Were I to redo mine Lemans, I would have 2-1/2" head pipes with 2-1/4" tail pipes. My T/A has the Thrush setup; quiet but not OEM quiet.
  #47
Old 03-18-2023, 12:40 AM
MUSLCAH MUSLCAH is offline
19 inch Flowmasters .....let it RIP
  #48
Old 04-13-2023, 03:30 PM
David Jones's Avatar
I've had the same 17749's (with an H-pipe) on my GTO now for about 20 years. Able to hold a conversation quiet inside the car and a nice rumble outside. With no other changes but the mufflers, I went from Flowmaster 50 series and an incredible drone inside the car to Dynomax 17749's and no drone or resonance.
  #49
Old 04-13-2023, 03:44 PM
65madgoat's Avatar
Spintech for the win. Can get them made as long, thin case, and/or wide as you can fit, "stuffed" inside if you want as well to knock down sound. Great muffler.
  #50
Old 04-13-2023, 09:43 PM
vertigto's Avatar
vertigto vertigto is offline
I have Flowmaster 40s that aren't for everyone. They're loud...but I'm loving the exhaust note/tone. Very aggressive, but at 55 mph (3.23) with windows down we were able to easily talk. Might get a little old over time... we'll see. It's always been part of the musclecar experience for me.
I need to record it.
  #51
Old 04-15-2023, 12:41 AM
R 70 Judge's Avatar
Originally Posted by R 70 Judge View Post
I’m looking at muffler options for my 70 TA. I’ve heard these Black Widow Venom 250’s on Autotopia and they sound great. Very unique sound. Has there been any outside testing on them? It’s similar to a spintech or flowmaster since it’s chambered.
I’m considering the Venom 250 in 3”. My current engine makes around 660hp. Next year when it’s turbo’d it will be in the neighborhood of 1200hp-1300hp
https://youtu.be/NPhCFPeLTjQ
https://blackwidowexhaust.com/mufflers/
I ended up going with a set of 3” Hooker aero chambers and 3” Pypes exhaust. Everything fit great. No complaints. We are finishing up the efi conversion but it should be running in the next couple weeks so I can see how it sounds.
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
  #52
Old 08-12-2023, 05:06 PM
R 70 Judge's Avatar
Pypes full 3” exhaust with X and Hooker Aerochamber mufflers
Sounds amazing!!
https://youtu.be/-XGWLuEwyso
James
1970 Trans Am
  #53
Old 09-03-2023, 02:08 PM
DanC's Avatar
DanC DanC is offline
Question Hush Thrust?
Pipe size makes a big difference - 17749's and their 2-1/4" equivalent are different in their noise level. 2-1/4" are almost factory quiet. My T/A has the Thrush setup; quiet but not OEM quiet.
Which Thrust do you have? I was thinking of using the Hush Thrust, but wondering if it might be too quiet on my Esprit.
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
