Old 10-28-2020, 01:07 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Viking Coilovers or Moroso trick springs & 90/10 shocks?
A couple of years ago, in order to shave weight for hard tire heads up racing, I replaced my front shock/spring combo with a set of Viking double adj coil over springs. It seemed like a good idea but I now wonder if that was a mistake since I have a lower HP car (425 on motor, 605 on n2o), would I be better off going back some Moroso trick front springs and a good set of 90/10 shocks? The car weighs 3280lb with 1710lb on the front.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 10-28-2020, 03:24 PM
Mike Davis's Avatar
Santhuff Springs and Viking DA would be my choice.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-28-2020, 10:44 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I went from Moroso trick springs and Calvert 90/10 shocks to Viking bolt on coilovers this past winter. With the Moroso springs, my car would pop the front up then drop it quickly and actually bounce the front tires a few times after launch. Also, the front suspension would be fully extended all the way down the track. The Vikings are a huge improvement on the street and track. Weight savings, ride height adjustability, compression and rebound damping adjustability.....what's not to like?
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 10-29-2020, 07:50 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Coil springs and a good shocks.
I have two Pontiac buds running pretty quick with coils and good shocks.
One runs 9.50s,the other high 7s.
Both on small tire.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 10-29-2020, 11:07 AM
Scott65's Avatar
Scott65 Scott65 is offline
I'd like to hear more. Type of lower a arms, modification required etc. I have a set of Santhuffs I'm gonna have to replace with something soon. After 10 years, but not a lot of use, they've sagged some. I've considered a coilover conversion, but not heard a lot of great experiences.
Old 10-29-2020, 01:24 PM
I'm still using OE upper and lower arms. The kit I bought uses a hybrid spring. The upper end seats in the OE spring seat and the lower end seats on the shock body. The installation was fairly straight forward. I did have to drill out the welded "nuts" in the lower control arms so a 3/8" bolt could pass through. I also had to enlarge the holes in the subframe where the shock body passes through. I think over the winter, I will remove the lower control arms and reinforce the area where the shock cross bar mounts since that small area now supports the weight of the front end.
I let Mike Proulx at Viking select the springs and shock damping for me. He has been very helpful. One of the reasons I went with the hybrid coilover set up, is because it allows easy access to the adjustment knobs on the DA shock. I use different settings for street and strip so I adjust them quite a bit.
'68 Firebird
Old 10-29-2020, 01:27 PM
Scott65's Avatar
Thanks for that. I'm gonna check into it further.
