Old 10-28-2020, 06:06 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by pggto View Post
Heres a few pictures of the original interior in my 73 project car for reference. Anybody know how to get tire stains out? The plastic has faded and changed colors over the years so I would be interested in what dyes work to restore the color as well.
Looks like my interior color wise
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
  #42
Old 10-28-2020, 06:08 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by njsteve View Post
I know I'm late to the party but this was an exact match to the dark saddle on my '73 SD survivor car and my 1975 Gramma's car (Esprit). I got it from NPD.
https://www.npdlink.com/product/inte...ray-can/122745
SEM custom mixed C-VP5855 for 71-72 Camaro. I have no idea why they had it primarily listed under a Camaro application which it is wrong for, but it is perfect for the 73 Firebird. I used it for the inside door strap pull caps when I had to replace them on my 75.
So Steve this can Is a very nice match to above pics on the interior ....
  #43
Old 10-28-2020, 06:13 PM
cnc's Avatar
cnc cnc is offline
Steve how many cans would u think for sail panels,kick panels, A posts and the other remaining trim surronds 2 cans....???
  #44
Old 10-28-2020, 06:46 PM
vertigto's Avatar
vertigto vertigto is offline
I did kick panels, seat backs/bases, armrest bases/pads, console cover and rear side panels/armrests and it took exactly 3 cans of Color Coat.
I would get an extra can, just in case. You don't want to be short.
  #45
Old 10-28-2020, 09:50 PM
njsteve's Avatar
njsteve njsteve is offline
I'd say buy four cans if you're doing a lot of the interior. You never know when they will stop selling this custom blended color. SEM is a great product. Make sure you do a lot of light coats or else you risk filling up the grain if the coast is too thickly applied.
  #46
Old 10-29-2020, 07:07 AM
cnc's Avatar
cnc cnc is offline
I see the can says plastics , vinyl , velour etc .......ever used it on metal with any results .....A posts are metal so just curious....
I guess I could get some one to mix something to work with metal if this is not applicable...matching it to this SEM PRODUCT
  #47
Old 10-29-2020, 09:50 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
It's PAINT.....with flex agents etc.....and will stick to most anything that is prepped properly...
Good prep...is the key to ANY successful paint job.......Read the directions....
Use SEM CLEAN....prior to painting....
  #48
Old 10-29-2020, 03:49 PM
njsteve's Avatar
The SEM product works great on everything. I use the SEM Landau Black for interior stuff, metal trim, it's awesome for radiator shrouds!
I just used SEM White interior dye on the metal interior trim (changed it over from black) on my 70 Cuda and it worked great. I used regular grey sandable primer first, on the metal parts just so the dye would have better coverage.
  #49
Old 10-29-2020, 07:26 PM
cnc's Avatar
cnc cnc is offline
Figured it would but had to ask...yes prep is key to all applications of paint
  #50
Old 11-01-2020, 09:30 AM
cnc's Avatar
cnc cnc is offline
Thought I'd update with my findings.ive ordered a can of Saddle Tan from a dealer around here as soon as I get it I'll post a pic ....I saw the pant chip via a text pic....so will see
  #51
Old 11-02-2020, 07:47 PM
cnc's Avatar
cnc cnc is offline
Cool! I'll keep it in mind. I have a can coming that I think will be close, but with my luck it's probably not.
Any update on your paint order ????
  #52
Old 11-02-2020, 07:59 PM
72projectbird's Avatar
I just sprayed the dash yesterday. It's closer, but not perfect. Still on the light side.
Good news is the headliners and rug came in, and they match perfectly.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #53
Old 11-02-2020, 11:25 PM
njsteve's Avatar
Remember that the interior panels did not all have the exact same color. Here's my 75 and my 73. Both unrestored original.
ID:	552949   Click image for larger version
  #54
Old 11-04-2020, 09:01 PM
cnc's Avatar
cnc cnc is offline
My paint is in and I will have it Sat so I’ll post up some pics on the weekend of the paint and compare....
  #55
Old 11-05-2020, 05:29 PM
Brad Pringle's Avatar
Brad Pringle Brad Pringle is offline
Keep us up to date. i have a 74 that could use some touching up. Thank You
Brad Pringle
Wellston, Michigan
1973 SD 455 TA Auto
1974 SD455 TA 4 Spd
  #56
Old 11-05-2020, 07:56 PM
cnc's Avatar
cnc cnc is offline
Can we see a pic of the dash I need to do mine too...
  #57
Old 11-07-2020, 06:03 PM
cnc's Avatar
cnc cnc is offline
So went to pick up the paint I ordered and just by looking at the lid it was waaaaaay to light almost like the pics of the buckskin in the samples...
I had taken my A post covers with me and the lady at the counter (Crystal) got out her paint chip books and they had a hole in the centre so we could lay it over top of the A post and choose something very close....
She mixed it up and adjusted the tone to this .....
I shot the back side edge it's about 1/4 wide of one of my A post to compare with the frt side of the other ...here is the result..
What ya think????
ID:	553224   Click image for larger version
ID:	553225   Click image for larger version
ID:	553226   Click image for larger version
ID:	553227   Click image for larger version
  #58
Old 11-07-2020, 06:21 PM
cnc's Avatar
cnc cnc is offline
Here is the paint code she mixed it and put in an aerosol for me ...
  #59
Old 11-08-2020, 04:52 PM
Looks pretty good to me, considering the crap I've been dealing with. lol
1987 Grand National
  #60
Old 11-08-2020, 05:15 PM
vertigto's Avatar
Looks great.
FWIW...originally I don't think the A-pillar matched exactly the rest of the interior (mine didn't). But I agree that it looks much better this way.
