Viking Coilovers or Moroso trick springs & 90/10 shocks?
A couple of years ago, in order to shave weight for hard tire heads up racing, I replaced my front shock/spring combo with a set of Viking double adj coil over springs. It seemed like a good idea but I now wonder if that was a mistake since I have a lower HP car (425 on motor, 605 on n2o), would I be better off going back some Moroso trick front springs and a good set of 90/10 shocks? The car weighs 3280lb with 1710lb on the front.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Santhuff Springs and Viking DA would be my choice.
I went from Moroso trick springs and Calvert 90/10 shocks to Viking bolt on coilovers this past winter. With the Moroso springs, my car would pop the front up then drop it quickly and actually bounce the front tires a few times after launch. Also, the front suspension would be fully extended all the way down the track. The Vikings are a huge improvement on the street and track. Weight savings, ride height adjustability, compression and rebound damping adjustability.....what's not to like?
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
Coil springs and a good shocks.
I have two Pontiac buds running pretty quick with coils and good shocks. One runs 9.50s,the other high 7s. Both on small tire.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
'65 Tempest 467 3650# 11.30@120.31 |
I let Mike Proulx at Viking select the springs and shock damping for me. He has been very helpful. One of the reasons I went with the hybrid coilover set up, is because it allows easy access to the adjustment knobs on the DA shock. I use different settings for street and strip so I adjust them quite a bit.
Thanks for that. I'm gonna check into it further.
